Home » Modeling » QVT-OML » How to import a library
How to import a library [message #1784096] Thu, 22 March 2018 13:01 Go to next message
Francesco Bedini is currently offline Francesco BediniFriend
I have this content in eDSPNConstructors().qvto
modeltype EDSPN "strict" uses eDSPN(".../eDSPN");
library eDSPNConstructors(){
property randomSequence:Sequence(Integer) = Sequence{1,2,3,4,5,6,7,8,9};
/** Constructors **/
constructor Label::Label(given_text : String) {
Then in another file:
modeltype UML "strict" uses uml("http://www.eclipse.org/uml2/5.0.0/UML");
transformation AS2UPetriNetTransformation(in uml:UML, out net:EDSPN) extends library eDSPNConstructors();
I get the error: "Can't resolve module reference 'eDSPNConstructors'"
The file are both located into a "transforms" folder that is set as the QVT source container in the QVT Settings.
I also tried:
extends eDSPNConstructors();
Any idea? Does it make any sense to divide the helpers, query and constructors in different files?
Re: How to import a library [message #1784099 is a reply to message #1784096] Thu, 22 March 2018 14:17 Go to previous messageGo to next message
HI
I'm afraid that I have never used the library construct, but the QVTo JUnit tests have many examples of the form:
library SomeName;
The spec references as "extends SomeName" rather than your "extends library SomeName".
If you have many helpers, query and constructors separate files might be appropriate, but I would tend to modularize by partial model rather than implementation functionality.
Ed Willink
Re: How to import a library [message #1784202 is a reply to message #1784099] Fri, 23 March 2018 13:45 Go to previous messageGo to next message
I've found my problem, the
import libraryName;
at the beginning of the file using the library was missing.
Then the extends can be either with or without library.
Thanks for your help, to the next undocumented feature :)
Re: How to import a library [message #1784210 is a reply to message #1784202] Fri, 23 March 2018 14:26 Go to previous messageGo to next message
No Message Body
Re: How to import a library [message #1784212 is a reply to message #1784210] Fri, 23 March 2018 14:28 Go to previous message
So the "Can't resolve module reference 'eDSPNConstructors'" was 100% accurate.
You need to post fuller repros to avoid answers going off at a tangent.
Ed Willink
Previous Topic:Running a QVT transformation headless or from JUnit
Next Topic:a wrong with qvt
Current Time: Wed Jan 29 16:54:59 GMT 2020
Powered by FUDForum. Page generated in 0.02362 seconds
