Home » Modeling » QVT-OML » Running a QVT transformation headless or from JUnit(Running a QVT transformation headless or from JUnit)
Running a QVT transformation headless or from JUnit [message #1783993] Wed, 21 March 2018 10:03 Go to next message
Bruce Trask is currently offline Bruce TraskFriend
Member
Is there an example or doc for invoking a QVT transformation programmatically versus from a launch configuration? E.g from a JUnit test case?
Bruce
Re: Running a QVT transformation headless or from JUnit [message #1783995 is a reply to message #1783993] Wed, 21 March 2018 10:18 Go to previous message
The Eclipse QVTo project JUnit tests provide many examples, but they're hard to follow since they have smart configuration files to allow the same test code to support hundreds of tests.
(Eclipse QVTo provides Ant facilities but I really wouldn't recommend using Ant when MWE2 is so much better.)
GIT\org.eclipse.ocl\examples\org.eclipse.ocl.examples.build\src\org\eclipse\ocl\examples\build\utilities\QVToTransformationExecutor.java
is a Java bean that enables a QVTo transformation to be used within an MWE2 script. It is used by the auto-generation of the OCL Pivot.ecore and Java classes from UML.xmi + OCL.uml + MDTOCL.uml.
Ed Willink
Previous Topic:QVTO - Calling a mapping versus clone
Next Topic:How to import a library
Current Time: Tue Oct 15 21:35:30 GMT 2019
Powered by FUDForum. Page generated in 0.02799 seconds
