Home » Eclipse Projects » EGit / JGit » commit-id plugin reports that .gitconfig is invalid
commit-id plugin reports that .gitconfig is invalid [message #1783951] Tue, 20 March 2018 16:23 Go to next message
David M. Karr is currently offline David M. KarrFriend
I work on a Maven build that uses the git-commit-id plugin. I haven't run this build locally for a while. I recently had to tweak my user.name value in in my $HOME/.gitconfig to reflect corp standards. Today, when I tried to run that build, I saw an error like this:
[ERROR] Failed to execute goal pl.project13.maven:git-commit-id-plugin:2.2.3:revision (get-the-git-infos) on project ...: Could not complete Mojo execution...: Could not initialize repository... User config file ...\.gitconfig invalid org.eclipse.jgit.errors.ConfigInvalidException: Cannot read file ...\.gitconfig: Invalid line in config file -> [Help 1]
Here's the approximate contents of my entire $HOME/.gitconfig file:
[user]
	name = Karr, David (...)
	email = ...@...
I believe the former value of the "name" property was "David M. Karr". What might be happening here?
Re: commit-id plugin reports that .gitconfig is invalid [message #1783959 is a reply to message #1783951] Tue, 20 March 2018 17:25 Go to previous messageGo to next message
I think I figured this out. jgit was trying to read a file referenced by a Cygwin symlink, which unfortunately will not work.
Re: commit-id plugin reports that .gitconfig is invalid [message #1806101 is a reply to message #1783959] Thu, 02 May 2019 15:10 Go to previous message
himanshu singh is currently offline himanshu singhFriend
-> I think I figured this out. jgit was trying to read a file referenced by a Cygwin symlink, which unfortunately will not work.
I am facing the same issue.
I sync repositories using google repo tool on Windows 10 and use repo and git over cygwin.
But then the synced repositories are read through Jgit on windows system, then fails with
java.io.IOException: Unknown repository format
at org.eclipse.jgit.internal.storage.file.FileRepository.loadRepoConfig(FileRepository.java:249)
at org.eclipse.jgit.internal.storage.file.FileRepository.<init>(FileRepository.java:192)
at org.eclipse.jgit.storage.file.FileRepositoryBuilder.build(FileRepositoryBuilder.java:92)
Caused by: org.eclipse.jgit.errors.ConfigInvalidException: Cannot read file
Previous Topic:Problem with renaming file
Next Topic:Build and share EGit / JGit
Current Time: Sat Apr 04 19:32:03 GMT 2020
Powered by FUDForum. Page generated in 0.01429 seconds
