i am trying to Contribute a command to the rightlickmenu of the EMF Generator Model, right next to "Generate All" and i cant get it to work. Here is what i did:
plugin.xml:
<extension point="org.eclipse.ui.menus">
<menuContribution
locationURI="popup:org.eclipse.emf.codegen.ecore.genmodelMenuID?after=additions">
<command
commandId="someCommandId"
id="someId"
label="DoIt">
</command>
</menuContribution>
</extension>
<extension
point="org.eclipse.ui.commands">
<command
defaultHandler="java.path.to.the.handler.class.Handlerclass"
description="Some description"
id="someCommandId"
name="DoIt">
</command>
</extension>
Handlerclass:
public class Handlerclass extends AbstractHandler {
public Object execute(ExecutionEvent event) throws ExecutionException {
System.out.println("DoStuff");
return null;
public boolean isEnabled() {
return true;
public boolean isHandled() {
return true;
Am i missing something? Something wrong?
Thank you!
