Home » Newcomers » Newcomers » UML plugin for Python in Eclipse(Plugins for UML diagrams python)
UML plugin for Python in Eclipse [message #1783720] Fri, 16 March 2018 09:40 Go to next message
Mythri M is currently offline Mythri MFriend
I want to generate UML class diagrams for the python project developed in Eclipse. I tried to use PyUML but it did not work. The installation failed. Are there any other plugins that I can use? I need to add UML class diagrams in my project report. Please let me know if there are suitable plugins available which is working. I have PyDev already installed and the project is created using PyDev.
Re: UML plugin for Python in Eclipse [message #1783724 is a reply to message #1783720] Fri, 16 March 2018 09:57 Go to previous messageGo to next message
Asking on a PyDev forum would seem a more likely place to get an answer specific to your question.
Re: UML plugin for Python in Eclipse [message #1783767 is a reply to message #1783720] Fri, 16 March 2018 17:02 Go to previous messageGo to next message
Charles Rivet is currently offline Charles RivetFriend
Well... PyUML is very old. You might try installing on Eclipse Helios https://www.eclipse.org/helios/ or Ganymede https://www.eclipse.org/ganymede/Ganymede...
Else, follow Ed's advice...
/Charles Rivet
Re: UML plugin for Python in Eclipse [message #1803645 is a reply to message #1783720] Wed, 06 March 2019 05:01 Go to previous message
Dylan Harrison is currently offline Dylan HarrisonFriend
You may have heard of Pylint that helps statically checking Python code. Few people know that it comes with a tool named Pyreverse that draws UML diagrams from the python code it reads. Pyreverse(ttrockstars) uses graphviz as a backend.
[Updated on: Wed, 06 March 2019 07:18]
Report message to a moderator
Previous Topic:Eclipse CPP 2018-12
Next Topic:The origin server did not find a current representation for the target resource or is not willing to
Current Time: Sun Sep 22 10:45:16 GMT 2019
Powered by FUDForum. Page generated in 0.03337 seconds
