Load all projects from a folder. [message #1783528] |
Tue, 13 March 2018 19:40 |
noor shiblee Messages: 5 Registered: November 2017 |
I am facing a problem while loading some projects one by one.
My target is to load 10 folders(10 project) using rcptt from another folder.
Project-dest
|____________proj1
|____________proj2
|____________proj3
|____________proj4
|____________proj5
|____________proj6
Folder "Project-dest" contains 10 projects.Target is to load all project one by one.
I am using the below code:
proc "load-project-from-workspace" {
loop [val count 0] {
if [$count | lt 10] {
//script to load the project.
set-dialog-result Folder "/home/test-project/test/Project-dest/" $count
//target is loading /home/test-project/test/Project-dest/proj[1]
//script to do some other stuff.
recur [$count | plus 1]
But the problem is it loads all 10 project at a time instead of loading one by one.
Need help related this things.
[Updated on: Tue, 13 March 2018 19:42] Report message to a moderator
FUDForum. Page generated in 0.02952 seconds
