Home » Language IDEs » C / C++ IDE (CDT) » RE: Running Some Software Out of a Book(g++ and gcc are Not Being Recognized in my PATH)
RE: Running Some Software Out of a Book [message #1783281] Sat, 10 March 2018 17:44 Go to next message
I am reading a book on C++ and it has examples. I am only on Ch. 2 but the book is interesting.
I thought I could use this Eclipse CDT for C/C++ developers w/ ease. I have been proven wrong. I saw the info. on the tutorials website. I thought they were interesting but I did not see a section for making my current software work.
I am receiving bug after bug. I will leave some photos of the issue soon.
Seth
index.php/fa/32274/0/
P.S. Here is the new error code after restarting the Eclipse IDE.
index.php/fa/32275/0/
[Updated on: Sat, 10 March 2018 17:47] by Moderator
Report message to a moderator
Re: RE: Running Some Software Out of a Book [message #1783282 is a reply to message #1783281] Sat, 10 March 2018 18:03 Go to previous messageGo to next message
Hello...
I saved the file and I still receive the same error.
Seth
Re: RE: Running Some Software Out of a Book [message #1783283 is a reply to message #1783282] Sat, 10 March 2018 18:23 Go to previous messageGo to next message
For an update:
I am using Win 10 and Eclipse Oxygen 4.7.2. I have installed CygWin and the libraries I needed to set up for makefiles, gdb, and gcc.
Seth
P.S. I got to the CygWin page where I select packages b/c I have a new error when applying the info. from http://help.eclipse.org/oxygen/index.jsp?nav=%2F0. The error is different but it is b/c I do not have the right "make" installed, presumably. Do you know which "make" I need to install on CygWin?
index.php/fa/32278/0/
index.php/fa/32279/0/
[Updated on: Sat, 10 March 2018 21:38] by Moderator
Re: RE: Running Some Software Out of a Book [message #1783290 is a reply to message #1783283] Sun, 11 March 2018 02:13 Go to previous message
Hello...
I finished my first program and I found make in the system, i.e. the correct "make" to use. Forget the replies. Thank you for anyone who had read my garbled sum.
Seth
P.S. Thank you again.
Previous Topic:Unable to debug on El Capitan
Next Topic:Can't use MySQL Connector to deploy a C++ program
Current Time: Sun Feb 09 09:19:32 GMT 2025
Powered by FUDForum. Page generated in 0.03928 seconds
