Home » Eclipse Projects » NatTable » Sorting not proper
Sorting not proper [message #1783125] Thu, 08 March 2018 07:15 Go to next message
Gaurav Tripathi is currently offline Gaurav TripathiFriend
Member
In NatTable, I have the column which contains a string like String1, String2, String3, String10, String100.
I have used GlazedListsSortModel within my SortHeaderLayer and added SingleClickSortConfiguration.
So when I click on this header it is sorting like below:
For example String1, String3, String2, String100, String10
After sorting it is showing like this :
String1, String10, String100, String2, String3 instead of
I am not able to catch why so happening?
Is there any solution for same?
Re: Sorting not proper [message #1783133 is a reply to message #1783125] Thu, 08 March 2018 11:26 Go to previous message
Dirk Fauth is currently offline Dirk FauthFriend
That is the sorting that is done by simply comparing the strings. And this is done by the DefaultComparator we configure by default. If you want a different sorting you need to implement and register a custom comparator.
Previous Topic:Cell painting with Combination of images
Next Topic:Custom persistence behavior and modifying the PersistenceDialog
Current Time: Wed Oct 16 17:02:01 GMT 2019
Powered by FUDForum. Page generated in 0.02064 seconds
