Re: Custom layout not getting invoked [message #1783685 is a reply to message #1782999] |
Thu, 15 March 2018 14:11 |
Pierre Guilet Messages: 250 Registered: June 2017 |
ELK v0.3 has a GMF connector providing DRAW2D layouting registered with Highest priority.
If you have not a higher priority for your provider but the same one, the first or last compatible provider is used and in your case it is not yours.
I think ELK should not set the highest priority for its GMF connector.
The only solution is to not have this connector installed.
In our integration we have our own Sirius connector that will allow to use any ELK layout algorithm. But the problem will be the same if you install the ELK GMF connector.
Pierre Guilet - Obeo
FUDForum. Page generated in 0.01717 seconds
