Re: Maintaining Graphical layout of Elements in Model [message #1782732 is a reply to message #1782730] |
Wed, 28 February 2018 15:19 |
Hi.
This is the expected behavior. Every diagram (or table, or tree) created on a given semantic model is a different view of that model. If two diagrams of the same type (same definition in the .odesign file) exist on the exact same model, they will have the same structure (e.g. same number of nodes, containers and relationships between them), at least by default, but their layout information (size and position of elements, which one are pinned or not, etc.) are independent.
You can try to use the Copy/Paste layout feature (see https://www.eclipse.org/sirius/doc/user/diagrams/Diagrams.html#copy_paste_format), but I'm not sure it will work in your case as it was designed with diagrams from the same project (session) in mind, and in your case the MP1 and MP2 are different projects (even if each loads the same physical file on disk, they are independant entities).
Pierre-Charles David - Obeo
FUDForum. Page generated in 0.02188 seconds
