RAW coder and arrays in records [message #1782722] |
Wed, 28 February 2018 13:12 |
I'm a bit puzzled on how to use an array of one record in another record without loosing the ability to use the RAW codec:
module PCUIF_Proto {
type record PCUIF_InfoTrx {
uint16_t arfcn,
BIT8 pdch_mask,
OCT1 spare,
OCT8 tsc,
uint32_t hLayer1
} with { variant "" };
type record PCUIF_info_ind {
uint32_t version,
PCUIF_Flags flags,
PCUIF_InfoTrx trx[8],
} with { encode "RAW" };
will fail to compile with titan 6.3.0, while titan claiming that PCUIF_info_ind cannot be encoded as RAW. However, when removing the array it can.
What am I missing here? If the size / encoding of an array element is known, why is the size/encoding of an array of those elements not known? What should I do to make the RAW codec understand this? Thanks!
Re: RAW coder and arrays in records [message #1782725 is a reply to message #1782722] |
Wed, 28 February 2018 13:44 |
Hi Harald,
the RAW codec was not extended to arrays, see refguide
4.34 4.23 RAW Encoder and Decoder
You can use the encoding rules defined in this section to encode and decode the following TTCN3 types:
• bitstring
• boolean
• charstring
• enumerated
• float
• hexstring
• integer
• octetstring
• record
• record of, set of
• set
• union
• universal charstring
(no array here)
The why is lost in the depths of time, but I suspect it has to do with the fact
that arrays are not so much useful and they can be replaced with "record of" structures.
So I suggest you try the same:
uint16_t arfcn,
BIT8 pdch_mask,
OCT1 spare,
OCT8 tsc,
uint32_t hLayer1
type record length(8) of PCUIF_InfoTrx RecOfPCUIF_InfoTrx ;
uint32_t version,
PCUIF_Flags flags,
// PCUIF_InfoTrx trx[8]
RecOfPCUIF_InfoTrx trx
should give you the desired encoding.
I hope this helps
BR
Elemer
FUDForum. Page generated in 0.03410 seconds
