Re: Indexer's extern "C" confusion [message #1782759 is a reply to message #1782754] |
Thu, 01 March 2018 06:14 |
David Vavra Messages: 1426 Registered: October 2012 |
The index is merely a database. It's up to the discovery providers and scanner to fill it.
The built-ins provider is the one to fill in predefined macros.
Since you don't have one, you need to do it manually.
What you might want to consider is a file that contains the definitions and add it as a user entry in
Project --> Properties --> C/C++ General --> Preprocessor Include Paths, Macros etc.
You might want to file an enhancement request in Bugzilla to have built-in defaults for standard macros.
[Updated on: Thu, 01 March 2018 06:52] Report message to a moderator
Re: Indexer's extern "C" confusion [message #1782773 is a reply to message #1782759] |
Thu, 01 March 2018 09:17 |
Tauno Voipio Messages: 742 Registered: August 2014 |
I had an analogous problem with cross-compilation to a Cortex-M4 ARM. There are actually hundreds of predefined constants in the compiler (351 for Cortex-M4) in addition to the __cplusplus.
I pushed the GCC to create a header file of the includes:
arm-none-eabi-gcc -mthumb -mcpu=cortex-m4 -E -dM >cortexm4-predef.h
and added it to the indexer includes.
Many of the standard library headers depend on the constants in the predefinition file, and this keeps the indexer happy with them.
Tauno Voipio
FUDForum. Page generated in 0.02600 seconds
