Home » Newcomers » Newcomers » info lost in file conversion (vcf)(vcf file only has first 100 lines)
info lost in file conversion (vcf) [message #1782680] Tue, 27 February 2018 20:03 Go to next message
Alex B is currently offline Alex BFriend
I have some data in an excel file that is several thousands of lines long but I have a vcf file that I think was made from the excel file by someone else that is only 100 lines long. When I realized the vcf file did not contain most of the information I tried converting the excel file to vcf. Doing this directly gave a corrupt file that contained long strings of nonsense characters.
Converting to from excel to csv to vcf again only gave the first 100 lines. Can eclipse only view the first 100 lines of a vcf file? Or was all that information really lost in the conversion?
I am running windows 10. Eclipse version Oxygen. I need to manipulate the vcf file with the plugin NGSEP but I don't think that matters for my problem.
Please let me know if you have any suggestions! Thanks!
Alex
Re: info lost in file conversion (vcf) [message #1782691 is a reply to message #1782680] Tue, 27 February 2018 23:23 Go to previous messageGo to next message
Nitin Dahyabhai is currently online Nitin DahyabhaiFriend
I think you'll want to talk with whomever supplies this "NGSEP" plug-in.
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: info lost in file conversion (vcf) [message #1782692 is a reply to message #1782691] Tue, 27 February 2018 23:57 Go to previous messageGo to next message
Sorry. I guess I didn't do a good job of explaining. I probably shouldn't have mentioned NGSEP at all. I didn't use NGSEP yet but I need the file to be in VCF format because I will use NGSEP and that is the only file type it accepts.
My question is how to convert an Excel file to a VCF file without losing any information?
Re: info lost in file conversion (vcf) [message #1802794 is a reply to message #1782692] Sat, 16 February 2019 05:13 Go to previous messageGo to next message
Aubree Davis is currently offline Aubree DavisFriend
My question is how to convert an Excel file to a VCF file without losing any information? [/quote]
Convert multiple contacts from Excel into VCF file format which is universally supported file format for contacts and once Excel contactsgets exported into vCard, it can easily be imported to almost all types of emails clients, etc. To convert you can try this osttopstapp.com/vcard-export-import.html Export VCF Import VCF for Outlook software. This task is possible via Excel to vCard conversion utility which is a specialized utility for exporting all contacts of Excel spreadsheet into single vCard file.
Re: info lost in file conversion (vcf) [message #1802865 is a reply to message #1802794] Mon, 18 February 2019 10:34 Go to previous message
Gerald Freeman is currently offline Gerald FreemanFriend
Yeah, I seem to have similar problem. Interesting responses, though.
Previous Topic:Trouble Running Oomph Installer
Next Topic:I found something what seems different very strange
Current Time: Thu Oct 01 02:39:53 GMT 2020
Powered by FUDForum. Page generated in 0.03371 seconds
