Home » Modeling » Papyrus » Lag because of BuddyClassLoading during XWT Introspection
Lag because of BuddyClassLoading during XWT Introspection [message #1782650] |
Tue, 27 February 2018 11:41 |
Thorsten Schlathölter Messages: 312 Registered: February 2012 Location: Düsseldorf |
we have embedded Papyrus in our application an experience lags due to the properties view which uses XWT. During creation of the XWT tabs, XWT uses introspection to check for BeanInfo classes. Since papyrus makes uses of buddy class loading there is quite a number of bundles which is searched for these BeanInfo classes which probably don't even exist. The lag is quite annoying 20-40 seconds and it is freezing the ui because the class loading takes place in the UI thread.
Is this a known issue?
This is an example of a stack. I just stopped the UI thread during the lag. The class which the classloader is currently looking for is:
org.eclipse.papyrus.infra.properties.ui.widgets.AbstractMultiReferenceBeanInfo
EquinoxContainerAdaptor$1(ClassLoader).findClass(String) line: not available
EquinoxContainerAdaptor$1(ClassLoader).loadClass(String, boolean) line: not available
EquinoxContainerAdaptor$1(ClassLoader).loadClass(String) line: not available
BundleLoader.findClassInternal(String, boolean) line: 479
BundleLoader.findClass(String, boolean) line: 395
BundleLoader.findClass(String) line: 387
DependentPolicy.loadClass(String) line: 55
PolicyHandler.doBuddyClassLoading(String) line: 141
BundleLoader.findClassInternal(String, boolean) line: 471
EquinoxClassLoader(ModuleClassLoader).loadClass(String, boolean) line: 150
EquinoxClassLoader(ClassLoader).loadClass(String) line: not available
Class<T>.forName0(String, boolean, ClassLoader, Class<?>) line: not available [native method]
Class<T>.forName(String, boolean, ClassLoader) line: not available
ClassFinder.findClass(String, ClassLoader) line: not available
BeanInfoFinder(InstanceFinder<T>).instantiate(Class<?>, String) line: not available
BeanInfoFinder(InstanceFinder<T>).find(Class<?>) line: not available
Introspector.findExplicitBeanInfo(Class<?>) line: not available
Introspector.<init>(Class<?>, Class<?>, int) line: not available
Introspector.getBeanInfo(Class<?>) line: not available
Introspector.getBeanInfo(Class<?>, Class<?>, int) line: not available
Metaclass(AbstractMetaclass).initialize(Class<?>, IMetaclass) line: 685
Metaclass(AbstractMetaclass).assertInitialize() line: 677
Metaclass(AbstractMetaclass).newInstance(Object[]) line: 395
ResourceLoader.doCreate(Object, Element, Class<?>, Map<String,Object>) line: 613
ResourceLoader.doCreate(Object, Element, Class<?>, Map<String,Object>) line: 717
ResourceLoader.createUIElement(Element, Map<String,Object>) line: 378
PapyrusXWTCore(Core).createCLRElement(IRenderingContext, Element, Map<String,Object>) line: 630
PapyrusXWTCore(Core).load(ILoadingContext, InputStream, URL, Map<String,Object>) line: 772
PapyrusXWTCore(Core).load(ILoadingContext, URL, Map<String,Object>) line: 660
XWTLoader.loadWithOptions(URL, Map<String,Object>) line: 1072
Thanks in advance.
Thorsten
Current Time: Wed Apr 24 17:28:21 GMT 2024
Powered by FUDForum. Page generated in 0.02831 seconds
