Home » Newcomers » Newcomers » Maven Build Failure - Eclipse Smart Home Core - Ubuntu 16.04(Attempting to load Eclipse Smart Home on Ubuntu via Maven - Fails on Core)
Maven Build Failure - Eclipse Smart Home Core - Ubuntu 16.04 [message #1782479] Fri, 23 February 2018 20:22 Go to next message
Michael Hoyle is currently offline Michael HoyleFriend
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary:
[INFO]
[INFO] Eclipse SmartHome .................................. SUCCESS [ 0.442 s]
[INFO] Eclipse SmartHome Bundles .......................... SUCCESS [ 0.127 s]
[INFO] Eclipse SmartHome Test Components .................. SUCCESS [ 0.056 s]
[INFO] Eclipse SmartHome Core Components .................. SUCCESS [ 0.110 s]
[INFO] Eclipse SmartHome Core ............................. FAILURE [ 19.859 s]
[INFO] Eclipse SmartHome Configurations ................... SKIPPED
[INFO] Eclipse SmartHome Configuration Core ............... SKIPPED
[INFO] Eclipse SmartHome Configuration XML ................ SKIPPED
[INFO] Eclipse SmartHome AutoUpdate Binding ............... SKIPPED
[INFO] Eclipse SmartHome Test ............................. SKIPPED
[INFO] Eclipse SmartHome I/O Components ................... SKIPPED
[INFO] Eclipse SmartHome Console .......................... SKIPPED
[INFO] Eclipse SmartHome Thing ............................ SKIPPED
[INFO] Magic Bundle ....................................... SKIPPED
[INFO] Magic Bundle Tests ................................. SKIPPED
[INFO] Eclipse SmartHome Auth Components .................. SKIPPED
[INFO] Eclipse SmartHome JAAS Authentication .............. SKIPPED
[INFO] Eclipse SmartHome Configuration Dispatcher ......... SKIPPED
[INFO] Eclipse SmartHome Configuration Dispatcher Tests ... SKIPPED
[INFO] Eclipse SmartHome Configuration Core Tests ......... SKIPPED
[INFO] Eclipse SmartHome Configuration Discovery .......... SKIPPED
[INFO] Eclipse SmartHome mDNS Service ..................... SKIPPED
[INFO] Eclipse SmartHome Configuration mDNS Discovery ..... SKIPPED
[INFO] Eclipse SmartHome Core Thing XML ................... SKIPPED
[INFO] Eclipse SmartHome Configuration Discovery Tests .... SKIPPED
[INFO] Eclipse SmartHome Configuration UPnP Discovery ..... SKIPPED
[INFO] Eclipse SmartHome Configuration Serial ............. SKIPPED
[INFO] Eclipse SmartHome Config XML Tests ................. SKIPPED
[INFO] Eclipse SmartHome Core Audio ....................... SKIPPED
[INFO] Eclipse SmartHome Core Binding XML ................. SKIPPED
[INFO] Eclipse Smarthome Audio Test ....................... SKIPPED
[INFO] Eclipse SmartHome Sample Extension Service ......... SKIPPED
[INFO] Eclipse SmartHome REST Interface ................... SKIPPED
[INFO] Eclipse SmartHome Core ID .......................... SKIPPED
[INFO] Eclipse SmartHome ID Tests ......................... SKIPPED
[INFO] Eclipse SmartHome Core Tests ....................... SKIPPED
[INFO] Eclipse SmartHome Thing Tests ...................... SKIPPED
[INFO] Eclipse SmartHome Core Persistence ................. SKIPPED
[INFO] Eclipse SmartHome Core Scheduler Service ........... SKIPPED
[INFO] Eclipse SmartHome Core Transformation Service ...... SKIPPED
[INFO] Eclipse SmartHome Core Binding XML Tests ........... SKIPPED
[INFO] Eclipse SmartHome Core Thing XML Tests ............. SKIPPED
[INFO] Eclipse SmartHome Core Voice ....................... SKIPPED
[INFO] Eclipse SmartHome Core Voice Test .................. SKIPPED
[INFO] Eclipse SmartHome Automation ....................... SKIPPED
[INFO] Eclipse SmartHome Automation API ................... SKIPPED
[INFO] Eclipse SmartHome Automation Commands .............. SKIPPED
[INFO] Eclipse SmartHome Automation Parser GSON ........... SKIPPED
[INFO] Eclipse SmartHome Automation Providers ............. SKIPPED
[INFO] Eclipse SmartHome Automation Provider File ......... SKIPPED
[INFO] Eclipse SmartHome Automation Core .................. SKIPPED
[INFO] Eclipse SmartHome Automation Core Tests ............ SKIPPED
[INFO] Eclipse SmartHome Automation Sample JSON ........... SKIPPED
[INFO] Eclipse SmartHome Automation Core Modules .......... SKIPPED
[INFO] Eclipse SmartHome Automation Core Module Tests ..... SKIPPED
[INFO] Eclipse SmartHome Automation Script Modules ........ SKIPPED
[INFO] Eclipse SmartHome Automation Media Modules ......... SKIPPED
[INFO] Eclipse SmartHome Automation Timer Modules ......... SKIPPED
[INFO] Eclipse SmartHome Automation Module Timer Tests .... SKIPPED
[INFO] Eclipse SmartHome Automation Script Default Scope .. SKIPPED
[INFO] Eclipse SmartHome Automation Script RuleSupport .... SKIPPED
[INFO] Eclipse SmartHome Automation Script Module Tests ... SKIPPED
[INFO] Eclipse SmartHome Automation Event Tests ........... SKIPPED
[INFO] Eclipse SmartHome Automation Integration Tests ..... SKIPPED
[INFO] Eclipse SmartHome Automation Sample Extension Java . SKIPPED
[INFO] Eclipse SmartHome Automation REST API .............. SKIPPED
[INFO] Eclipse SmartHome Automation Sample REST API ....... SKIPPED
[INFO] Eclipse SmartHome Automation Java Demo ............. SKIPPED
[INFO] Eclipse SmartHome Automation Json Demo ............. SKIPPED
[INFO] Eclipse SmartHome Automation Module Type Demo ...... SKIPPED
[INFO] Eclipse SmartHome Console for OSGi framework Eclipse Equinox SKIPPED
[INFO] Eclipse SmartHome Console for OSGi Console RFC 147 . SKIPPED
[INFO] Eclipse SmartHome Console for OSGi runtime Karaf ... SKIPPED
[INFO] Eclipse SmartHome Monitor .......................... SKIPPED
[INFO] Eclipse SmartHome Network I/O ...................... SKIPPED
[INFO] Eclipse SmartHome Network I/O Tests ................ SKIPPED
[INFO] Eclipse SmartHome IO REST Tests .................... SKIPPED
[INFO] Eclipse SmartHome Authentication Support for the REST Interface SKIPPED
[INFO] Eclipse SmartHome Basic Auth for the REST Interface SKIPPED
[INFO] Eclipse SmartHome Core REST Interface .............. SKIPPED
[INFO] Eclipse SmartHome IO REST Core Tests ............... SKIPPED
[INFO] Eclipse SmartHome REST mDNS Announcer .............. SKIPPED
[INFO] Eclipse SmartHome REST JAX-RS Optimizations ........ SKIPPED
[INFO] Eclipse SmartHome SSE Interface .................... SKIPPED
[INFO] Eclipse SmartHome IO SSE Tests ..................... SKIPPED
[INFO] Eclipse SmartHome Models ........................... SKIPPED
[INFO] Eclipse SmartHome Model Core ....................... SKIPPED
[INFO] Eclipse SmartHome Model Lazy Generation ............ SKIPPED
[INFO] Eclipse SmartHome Model Sitemap .................... SKIPPED
[INFO] Eclipse SmartHome Model Items ...................... SKIPPED
[INFO] Eclipse SmartHome UIs .............................. SKIPPED
[INFO] Eclipse SmartHome UI ............................... SKIPPED
[INFO] Eclipse SmartHome Sitemap REST Interface ........... SKIPPED
[INFO] Eclipse SmartHome Sitemap REST Interface Tests ..... SKIPPED
[INFO] Eclipse SmartHome Core REST UI Logging Module ...... SKIPPED
[INFO] Eclipse SmartHome Voice REST Interface ............. SKIPPED
[INFO] Eclipse SmartHome DBus Transport ................... SKIPPED
[INFO] Eclipse SmartHome MQTT Transport ................... SKIPPED
[INFO] Eclipse SmartHome Mqtt Transport I/O Tests ......... SKIPPED
[INFO] Eclipse SmartHome UPnP Transport ................... SKIPPED
[INFO] Eclipse SmartHome IO UPnP Tests .................... SKIPPED
[INFO] Eclipse SmartHome Model Core Tests ................. SKIPPED
[INFO] Eclipse SmartHome Model Item IDE ................... SKIPPED
[INFO] Eclipse SmartHome Model Items Runtime .............. SKIPPED
[INFO] Eclipse SmartHome Items Model Tests ................ SKIPPED
[INFO] Eclipse SmartHome Model Persistence ................ SKIPPED
[INFO] Eclipse SmartHome Model Persistence IDE ............ SKIPPED
[INFO] Eclipse SmartHome Model Script ..................... SKIPPED
[INFO] Eclipse SmartHome Model Rules ...................... SKIPPED
[INFO] Eclipse SmartHome Model Rule IDE ................... SKIPPED
[INFO] Eclipse SmartHome Model Script IDE ................. SKIPPED
[INFO] Eclipse SmartHome Model Sitemap IDE ................ SKIPPED
[INFO] Eclipse SmartHome Thing Model ...................... SKIPPED
[INFO] Eclipse SmartHome Model Thing IDE .................. SKIPPED
[INFO] Eclipse SmartHome Language Server .................. SKIPPED
[INFO] Eclipse SmartHome Language Server Tests ............ SKIPPED
[INFO] Eclipse SmartHome Model Persistence Runtime ........ SKIPPED
[INFO] Eclipse SmartHome Model Persistence Tests .......... SKIPPED
[INFO] Eclipse SmartHome Model Rules Runtime .............. SKIPPED
[INFO] Eclipse SmartHome Model Rules Tests ................ SKIPPED
[INFO] Eclipse SmartHome Model Script Runtime ............. SKIPPED
[INFO] Eclipse SmartHome Model Script Tests ............... SKIPPED
[INFO] Eclipse SmartHome Model Sitemap Runtime ............ SKIPPED
[INFO] Eclipse SmartHome Thing Model Runtime .............. SKIPPED
[INFO] Eclipse SmartHome Thing Model Tests ................ SKIPPED
[INFO] Eclipse SmartHome UI Tests ......................... SKIPPED
[INFO] Eclipse SmartHome UI Icon Support .................. SKIPPED
[INFO] Eclipse SmartHome UI Icon Tests .................... SKIPPED
[INFO] Eclipse SmartHome Storages ......................... SKIPPED
[INFO] Eclipse SmartHome JSON Storage ..................... SKIPPED
[INFO] Eclipse SmartHome Storage JSON Tests ............... SKIPPED
[INFO] Eclipse SmartHome MapDB Storage .................... SKIPPED
[INFO] Eclipse SmartHome Storage MapDB Tests .............. SKIPPED
[INFO] Eclipse SmartHome Extensions ....................... SKIPPED
[INFO] Eclipse SmartHome Bindings ......................... SKIPPED
[INFO] Eclipse SmartHome Astro Binding .................... SKIPPED
[INFO] Eclipse SmartHome Astro Binding Tests .............. SKIPPED
[INFO] Eclipse SmartHome Bluetooth Binding ................ SKIPPED
[INFO] Eclipse SmartHome BlueZ Bluetooth Adapter .......... SKIPPED
[INFO] Eclipse SmartHome Bluetooth Binding Tests .......... SKIPPED
[INFO] Eclipse SmartHome DigitalSTROM Binding ............. SKIPPED
[INFO] Eclipse Smarthome DMX Binding ...................... SKIPPED
[INFO] Eclipse Smarthome DMX Binding Tests ................ SKIPPED
[INFO] Eclipse SmartHome hue Binding ...................... SKIPPED
[INFO] Eclipse SmartHome hue Binding Tests ................ SKIPPED
[INFO] Eclipse SmartHome FSInternetRadio Binding .......... SKIPPED
[INFO] Eclipse Smarthome FSInternetRadio Binding Test ..... SKIPPED
[INFO] Eclipse SmartHome LIFX Binding ..................... SKIPPED
[INFO] Eclipse SmartHome LIRC Binding ..................... SKIPPED
[INFO] Eclipse SmartHome NTP Binding ...................... SKIPPED
[INFO] Eclipse SmartHome NTP Binding Tests ................ SKIPPED
[INFO] SerialButton Binding ............................... SKIPPED
[INFO] Eclipse SmartHome Sonos Binding .................... SKIPPED
[INFO] TRÅDFRI Binding .................................... SKIPPED
[INFO] TRÅDFRI Binding Tests .............................. SKIPPED
[INFO] WeatherUnderground Binding ......................... SKIPPED
[INFO] Eclipse SmartHome WeMo Binding ..................... SKIPPED
[INFO] Eclipse SmartHome Wemo Binding Tests ............... SKIPPED
[INFO] Eclipse SmartHome YahooWeather Binding ............. SKIPPED
[INFO] Eclipse SmartHome Extension Service Extensions ..... SKIPPED
[INFO] Eclipse SmartHome IoT Marketplace Extension Service SKIPPED
[INFO] Eclipse SmartHome IoT Marketplace Extension Automation Support SKIPPED
[INFO] Eclipse SmartHome IoT Marketplace Extension Service Test SKIPPED
[INFO] Eclipse SmartHome I/O Services ..................... SKIPPED
[INFO] Eclipse SmartHome JavaSound I/O .................... SKIPPED
[INFO] Eclipse SmartHome Web Audio Support ................ SKIPPED
[INFO] Eclipse SmartHome Transformation Services .......... SKIPPED
[INFO] Eclipse SmartHome Exec Transformation Service ...... SKIPPED
[INFO] Eclipse SmartHome Javascript Transformation Service SKIPPED
[INFO] Eclipse SmartHome Map Transformation Service ....... SKIPPED
[INFO] Eclipse SmartHome Map Transformation Service Tests . SKIPPED
[INFO] Eclipse SmartHome Scale Transformation Service ..... SKIPPED
[INFO] Eclipse SmartHome Scale Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome RegEx Transformation Service ..... SKIPPED
[INFO] Eclipse SmartHome RegEx Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome XPath Transformation Service ..... SKIPPED
[INFO] Eclipse SmartHome XPath Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome JSonPath Transformation Service .. SKIPPED
[INFO] Eclipse SmartHome JSonPath Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome Xslt Transformation Service ...... SKIPPED
[INFO] Eclipse SmartHome Xslt Transformation Service Tests SKIPPED
[INFO] Eclipse SmartHome UI Extensions .................... SKIPPED
[INFO] Eclipse SmartHome Icon Sets ........................ SKIPPED
[INFO] Eclipse SmartHome Classic Icon Set ................. SKIPPED
[INFO] Eclipse SmartHome Basic UI ......................... SKIPPED
[INFO] Eclipse SmartHome Classic UI ....................... SKIPPED
[INFO] Eclipse SmartHome Paper UI ......................... SKIPPED
[INFO] Eclipse SmartHome Voice Services ................... SKIPPED
[INFO] Eclipse SmartHome MacOS TTS ........................ SKIPPED
[INFO] Eclipse SmartHome Mac TTS Tests .................... SKIPPED
[INFO] Eclipse SmartHome Features ......................... SKIPPED
[INFO] Eclipse SmartHome Runtime Core Feature ............. SKIPPED
[INFO] Eclipse SmartHome Runtime Model Feature ............ SKIPPED
[INFO] Eclipse SmartHome Runtime UI Feature ............... SKIPPED
[INFO] Eclipse SmartHome Runtime REST Feature ............. SKIPPED
[INFO] Eclipse SmartHome Runtime Automation Feature ....... SKIPPED
[INFO] Eclipse SmartHome Runtime Equinox Console Feature .. SKIPPED
[INFO] Eclipse SmartHome Runtime RfC147 Console Feature ... SKIPPED
[INFO] Eclipse SmartHome Runtime Binding Feature .......... SKIPPED
[INFO] Eclipse SmartHome Test Dependencies ................ SKIPPED
[INFO] Eclipse SmartHome Karaf Features ................... SKIPPED
[INFO] Eclipse SmartHome Target Platform Feature .......... SKIPPED
[INFO] Eclipse SmartHome Core Feature ..................... SKIPPED
[INFO] Eclipse SmartHome Extensions Feature ............... SKIPPED
[INFO] Eclipse SmartHome Karaf Feature Verification ....... SKIPPED
[INFO] Eclipse SmartHome Products ......................... SKIPPED
[INFO] Eclipse SmartHome p2 Repository .................... SKIPPED
[INFO] Eclipse SmartHome Tools ............................ SKIPPED
[INFO] Eclipse SmartHome Archetypes ....................... SKIPPED
[INFO] Eclipse Smarthome Binding Archetype ................ SKIPPED
[INFO] Eclipse Smarthome Binding Archetype Testsuite ...... SKIPPED
[INFO] Eclipse SmartHome Target Platform .................. SKIPPED
[INFO] Eclipse SmartHome Distribution ..................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 01:18 min
[INFO] Finished at: 2018-02-22T21:05:35-05:00
[INFO] Final Memory: 176M/480M
[ERROR] Failed to execute goal org.openhab.tools.sat:sat-plugin:0.4.1:findbugs (default) on project org.eclipse.smarthome.core: Execution default of goal org.openhab.tools.sat:sat-plugin:0.4.1:findbugs failed: A required class was missing while executing org.openhab.tools.sat:sat-plugin:0.4.1:findbugs: javax/xml/bind/JAXBException
[ERROR] -----------------------------------------------------
[ERROR] realm = plugin>org.openhab.tools.sat:sat-plugin:0.4.1
[ERROR] strategy = org.codehaus.plexus.classworlds.strategy.SelfFirstStrategy
[ERROR] urls[0] = file:/root/.m2/repository/org/openhab/tools/sat/sat-plugin/0.4.1/sat-plugin-0.4.1.jar
Re: Maven Build Failure - Eclipse Smart Home Core - Ubuntu 16.04 [message #1782486 is a reply to message #1782479] Sat, 24 February 2018 07:38 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
I'm not sure what your objective is with this "drive by" log output, but you forgot to ask any questions or supply any details that you couldn't just feed into a Google search.
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Sat, 24 February 2018 07:39]
Report message to a moderator
Re: Maven Build Failure - Eclipse Smart Home Core - Ubuntu 16.04 [message #1782490 is a reply to message #1782486] Sat, 24 February 2018 14:07 Go to previous messageGo to next message
I'm loading Eclipse Smart Home in Ubuntu 16.04 via Maven, mvn clean install, and the build always fails on the Eclipse Smart Home Core due to "Failed to execute goal org.openhab.tools.sat:sat-plugin:0.4.1:findbugs (default) on project org.eclipse.smarthome.core:". If I read this correctly, there is a missing class "A required class was missing while executing org.openhab.tools.sat:sat-plugin:0.4.1:findbugs: javax/xml/bind/JAXBException". Has anyone seen this and know how to fix it?
Re: Maven Build Failure - Eclipse Smart Home Core - Ubuntu 16.04 [message #1782492 is a reply to message #1782490] Sat, 24 February 2018 15:53 Go to previous messageGo to next message
David Wegener is currently offline David WegenerFriend
Are you running Maven on Java 9. If so, then my guess is you are encountering an issue with the new Java 9 module system. I don't know how enough about the new Java 9 module system to explain what is happening or how to fix it. There are some links below that have some information. You might try installing Java 8 and running Maven on that.
https://github.com/eclipse/jetty.project/issues/1265
http://mail.openjdk.java.net/pipermail/jdk9-dev/2016-May/004309.html
https://blog.codefx.org/java/java-9-migration-guide/ <- See section Dependencies on Java EE Modules
Re: Maven Build Failure - Eclipse Smart Home Core - Ubuntu 16.04 [message #1782658 is a reply to message #1782492] Tue, 27 February 2018 12:48 Go to previous message
I pulled back to Java 8, resolved the issue. Thanks for the assistance.
Previous Topic:Where is PDE
Next Topic:Publishing to JBoss 4.0.5 has encountered a problem
Current Time: Tue Jun 02 15:46:51 GMT 2020
Powered by FUDForum. Page generated in 0.03213 seconds
