Home » Eclipse Projects » Eclipse 4 » What is Eclipse 4 model services equivalent in Eclipse Oxygen(unable to complile E4 project on Eclipse Oxygen)
What is Eclipse 4 model services equivalent in Eclipse Oxygen [message #1782470] Fri, 23 February 2018 18:23 Go to next message
Ashish Tyagi is currently offline Ashish TyagiFriend
I am working on Eclipse RCP project which is based on Eclipse 4. I can build the project using Maven Tyco plugin but I am getting compiler error in Eclipse when Target Platform is Eclipse Oxygen. If I change the Target Platform to Eclipse Mars there is no Error. I really do not wants to have two separate installation on my computer. I also have Warnings to ignore: Preferences > search "compile" > Java > Compiler > Errors/Warnings >: search "serialize" > Ignore, "Forbidden Reference" > Ignore set to ignore Forbidden reference.
I have all the e4 tools installed in Eclipse. Is there something I am missing ? Can someone please help. The file which is missing is
org.eclipse.e4.ui.internal.workbench.XMLModelReconciler;
org.eclipse.e4.ui.internal.workbench.ModelReconcilingService;
org.eclipse.e4.ui.workbench.modeling.IModelReconcilingService;
org.eclipse.e4.ui.workbench.modeling.ModelDelta;
org.eclipse.e4.ui.workbench.modeling.ModelReconciler;
Any help would be much appreciated. Thanks
Re: What is Eclipse 4 model services equivalent in Eclipse Oxygen [message #1784801 is a reply to message #1782470] Wed, 04 April 2018 09:48 Go to previous messageGo to next message
py e4 is currently offline py e4Friend
https://stackoverflow.com/questions/48953424/eclipse-internal-file-can-not-be-found-in-eclipse-oxygen
Re: What is Eclipse 4 model services equivalent in Eclipse Oxygen [message #1785267 is a reply to message #1784801] Wed, 11 April 2018 18:16 Go to previous messageGo to next message
I asked the same question over there, it still does not resolve the issue because I still does not know the replacement class
Re: What is Eclipse 4 model services equivalent in Eclipse Oxygen [message #1785277 is a reply to message #1785267] Wed, 11 April 2018 21:53 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
What's the actual error message? Where do those come from when they are found?
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: What is Eclipse 4 model services equivalent in Eclipse Oxygen [message #1799108 is a reply to message #1785277] Thu, 29 November 2018 19:27 Go to previous message
Class can not be found as this class is internal
Previous Topic:Adding architecture to feature name
Next Topic:Part destruction when parent is removed from application model
Current Time: Thu Oct 01 19:55:02 GMT 2020
Powered by FUDForum. Page generated in 0.02438 seconds
