Re: Code coverage for Xtend (outside of maven build) [message #1841951 is a reply to message #1782627] |
Fri, 04 June 2021 06:51 |
Heinrich Weichert Messages: 1 Registered: June 2021 |
I know this is very old, but there is a solution.
(Working code, but could be cleaned up).
import java.util.List;
import java.util.Optional;
import javax.inject.Inject;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IWorkspaceRoot;
import org.eclipse.core.runtime.IAdapterFactory;
import org.eclipse.eclemma.core.CoverageTools;
import org.eclipse.eclemma.internal.core.analysis.JavaElementCoverageAdapterFactory;
import org.eclipse.emf.common.util.URI;
import org.eclipse.jdt.core.ICompilationUnit;
import org.eclipse.jdt.core.IJavaElement;
import org.eclipse.jdt.core.JavaCore;
import org.eclipse.ui.IFileEditorInput;
import org.eclipse.xtext.ui.generator.IDerivedResourceMarkers;
import org.jacoco.core.analysis.ICoverageNode;
@SuppressWarnings("restriction")
public class JavaElementAdapterFactory implements IAdapterFactory {
@Inject
private IDerivedResourceMarkers derivedResourceMarkers;
@Inject
private IWorkspaceRoot wsRoot;
public <T> T getAdapter(final Object adaptableObject, final Class<T> adapterType) {
if (adaptableObject instanceof IFileEditorInput && adapterType == IJavaElement.class) {
final IFileEditorInput input = (IFileEditorInput) adaptableObject;
try {
final List<IFile> resources = derivedResourceMarkers.findDerivedResources(wsRoot,
URI.createPlatformResourceURI(input.getFile().getFullPath().toString(), true).toString());
if (!resources.isEmpty()) {
final String fileName = input.getAdapter(IFile.class).getFullPath().removeFileExtension()
.lastSegment()
+ ".java";
final Optional<IFile> file = resources.stream()
.filter(r -> r.getName().equals(fileName))
.findFirst();
if (file.isPresent()) {
return adapterType.cast(JavaCore.create(file.get()));
} catch (final Exception e) {
// ignore
if (adaptableObject instanceof ICompilationUnit && adapterType == ICoverageNode.class) {
final ICoverageNode coverageInfo = (ICoverageNode) new JavaElementCoverageAdapterFactory()
.getAdapter(adaptableObject, adapterType);
if (coverageInfo != null && coverageInfo.containsCode()) {
return adapterType.cast(coverageInfo);
final ICompilationUnit unit = (ICompilationUnit) adaptableObject;
return adapterType
.cast(CoverageTools.getCoverageInfo(unit.getType(unit.getElementName().replace(".java", ""))));
return null;
public Class<?>[] getAdapterList() {
return new Class<?>[] { IFileEditorInput.class, ICompilationUnit.class };
This must be registered via an extension point:
<extension
point="org.eclipse.core.runtime.adapters">
<factory
adaptableType="org.eclipse.ui.IFileEditorInput"
class="com.company.JavaElementAdapterFactory">
<adapter
type="org.eclipse.jdt.core.IJavaElement">
</adapter>
</factory>
<factory
adaptableType="org.eclipse.jdt.core.ICompilationUnit"
<adapter
type="org.jacoco.core.analysis.ICoverageNode">
</adapter>
</factory>
</extension>
and additionally if using custom shortcuts, mode "coverage" needs to be added to these shortcuts.
<extension
point="org.eclipse.debug.ui.launchShortcuts">
<shortcut
label="My test"
helpContextId="org.eclipse.jdt.junit.launch_shortcut"
class="com.company.TestLaunchShortcut"
modes="debug,run,coverage"
id="com.company.debugLaunchShortCutProject">
Some UI widgets don't work this way, this can perhaps be improved. But you get the idea to go forward. Highlighting works in every xtext editor.
FUDForum. Page generated in 0.01885 seconds
