EMF Compare 3.2.1 and Oxygen [message #1782380] |
Thu, 22 February 2018 14:04 |
Simon BBBBBBB Messages: 63 Registered: March 2015 |
Member |
i build an application that works with emf compare 3.2.1 but not with a newer version. i tryed to install the 3.2.1 compare version into my oxygen eclipse and at first there where no problems. but my application wont work because it cant find the plugins. if i go to help -> about -> installation details i can see the plugins under installed software, but not under Plug-ins.
Any suggestions how i can solve this?
Thank you.
[Updated on: Thu, 22 February 2018 14:17] Report message to a moderator
Re: EMF Compare 3.2.1 and Oxygen [message #1782448 is a reply to message #1782380] |
Fri, 23 February 2018 14:51 |
Hello Simon,
Could you screenshot what you're seeing in "installation details" for emf compare on the "Installed software" tab and what your seeing (or not) where org.eclipse.emf.compare.* plugins should be in the "plug-ins" tab?
Laurent Goubet
Obeo
FUDForum. Page generated in 0.03222 seconds
