TestRunner not finding test suites in project [message #1782267] |
Wed, 21 February 2018 06:14 |
Bruce Edgerton Messages: 25 Registered: May 2017 |
I have created a number of projects within an RCPTT directory. Inside a project I have a test suite that I uses to run a set of tests. When the TestRunner scans my project structure, it doesn't pick up any test suites and reports there are no tests to be run. If I add a test to this project, TestRunner finds this and will execute my AUT just using that test. The documentation indicates that I can use a suites parameter, but this still doesn't find anything. Here is a copy of the command line file used to start TestRunner:
echo off
SET AUT=C:\Calypso
SET RUNNER=c:\apps\TestRunner\eclipse
SET PROJECT=C:\DEVROOT\calypso\client\trunk\RCPPT2
SET RESULTS=%PROJECT%\..\results
IF NOT EXIST %RESULTS% GOTO NORESULTS
RMDIR /S /Q %RESULTS%
:NORESULTS
md %RESULTS%
java -jar %RUNNER%/plugins/org.eclipse.equinox.launcher_1.4.0.v20161219-1356.jar ^
-application org.eclipse.rcptt.runner.headless ^
-data %RESULTS%/runner-workspace/ ^
-aut %AUT% ^
-autArgs -serverAddress;localhost:65000;-data;P:/calypso_uitests/ ^
-import %PROJECT%\AutoTest1;"%PROJECT%\Test Common" ^
-suites StaffProfileTests.suite ^
-autWsPrefix %RESULTS%/aut-workspace ^
-autConsolePrefix %RESULTS%/aut-output ^
-htmlReport %RESULTS%/report.html ^
-junitReport %RESULTS%/report.xml
AutoTest1 is the project the contains the suite that I want to run, Test Common is a project that holds procedure libraries.
Does anyone know how to use test suites properly in the TestRunner?Thanks in advance.
[Updated on: Wed, 21 February 2018 22:57] Report message to a moderator
Re: TestRunner not finding test suites in project [message #1782325 is a reply to message #1782284] |
Wed, 21 February 2018 22:55 |
Ulyana, thanks for the quick response. I added the .suite extension to the -suites argument (and moved it up - see the original text). This made no difference. The log contains the following:
progress: Reading plug-ins
Target platform is valid.
Looking for tests...
Existing projects in workspace:
<none>
Importing projects to workspace:
Refreshing projects:
C:\DEVROOT\calypso\client\trunk\RCPPT2\AutoTest1... OK
C:\DEVROOT\calypso\client\trunk\RCPPT2\Test Common... OK
AutoTest1... OK
Test Common... OK
Searching for tests in projects:
AutoTest1...
No tests found
Test Common...
No tests found
No tests to run.
Finished at Thu Feb 22 08:50:15 AEST 2018
Note: My project AutoTest1 contains only one test suite, namely StaffProfileTest.suite
If I add a single test to the AutoTest1 project and run the script with the -suites parameter, I still get no test found. If I remove the -suites parameter, the single test is picked up and run. The log looks like this:
<none>
AutoTest1... OK
Test Common... OK
AutoTest1...
Complete OK
Test Common...
No tests found
Testcase Artifacts:1
AUT-0:Launching
AUT-0:Product: calypso.product
AUT-0:Application: calypso.application
AUT-0:Architecture: x86
32bit arch is selected because AUT uses Equinox launcher
- C:plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.1.200.v20120522-1813\
C:\DEVROOT\calypso\client\trunk\RCPPT2\..\results/aut-workspace0: AUT arguments: -serverAddress localhost:65000 -data P:/calypso_uitests/ -os ${target.os} -arch ${target.arch} -con
soleLog
C:\DEVROOT\calypso\client\trunk\RCPPT2\..\results/aut-workspace0: AUT VM arguments: -Xms64m -Djava.library.path=C:\Progra~1\IBM\Lotus\Notes;C:\Progra~1\Lotus\Notes;C:\Progra~2\IBM\
Lotus\Notes;C:\Progra~2\Lotus\Notes; -DLOTUS_NOTES_HOME=C:\Progra~1\IBM\Lotus\Notes -DLOTUS_NOTES_HOME2=C:\Progra~1\Lotus\Notes -DLOTUS_NOTES_HOME3=C:\Progra~2\IBM\Lotus\Notes -DLO
TUS_NOTES_HOME4=C:\Progra~2\Lotus\Notes -Dorg.eclipse.swt.browser.DefaultType=ie -Dorg.eclipse.swt.browser.IEVersion=9999 -XX:+HeapDumpOnOutOfMemoryError -Dawt.useSystemAAFontSetti
ngs=on -Dswing.aatext=true -Djava.net.preferIPv4Stack=true -Xmx512m -XX:MaxPermSize=128m
Pass 1 (1) processed. 0 failed. spent: 0:03, 0:00 mins remaining. Test1. time: 2900ms
Process terminated. Shut down AUTs
Finished at Thu Feb 22 09:22:21 AEST 2018
[Updated on: Wed, 21 February 2018 23:23] Report message to a moderator
Re: TestRunner not finding test suites in project [message #1782695 is a reply to message #1782620] |
Wed, 28 February 2018 00:48 |
Both the test and the suite are in the AutoTest1 directory, these are the files:
AutoTest1
.project
rcptt.properties
runner.cmd
StaffProfileTests.sute
Test1.test
I open a cmd window and run the tests from that directory using the runner.cmd file (see at the top) without test parameters or "-tests Test1.test", the result is:
<none>
AutoTest1... OK
Test Common... OK
AutoTest1...
Complete OK
Test Common...
No tests found
AUT-0:Launching
C:\DEVROOT\calypso\client\trunk\RCPPT2\..\results/aut-workspace0: AUT arguments: -serverAddress localhost:65000 -data P:/calypso_uitests/ -os ${target.os} -arch ${target.arch} -consoleLog
C:\DEVROOT\calypso\client\trunk\RCPPT2\..\results/aut-workspace0: AUT VM arguments: -Xms64m -Djava.library.path=C:\Progra~1\IBM\Lotus\Notes;C:\Progra~1\Lotus\Notes;C:\Progra~2\IBM\Lotus\Notes;C:\Progr
a~2\Lotus\Notes; -DLOTUS_NOTES_HOME=C:\Progra~1\IBM\Lotus\Notes -DLOTUS_NOTES_HOME2=C:\Progra~1\Lotus\Notes -DLOTUS_NOTES_HOME3=C:\Progra~2\IBM\Lotus\Notes -DLOTUS_NOTES_HOME4=C:\Progra~2\Lotus\Notes
-Dorg.eclipse.swt.browser.DefaultType=ie -Dorg.eclipse.swt.browser.IEVersion=9999 -XX:+HeapDumpOnOutOfMemoryError -Dawt.useSystemAAFontSettings=on -Dswing.aatext=true -Djava.net.preferIPv4Stack=true -
Pass 1 (1) processed. 0 failed. spent: 0:03, 0:00 mins remaining. Test1. time: 2942ms
Finished at Wed Feb 28 10:28:56 AEST 2018
Note: Only 1 test artifact is found (this is Test1 based on the output). The result is as expected.
Using "-suites StaffProfileTests.suite" in the command file doesn't work. It produces this result:
<none>
AutoTest1... OK
Test Common... OK
AutoTest1...
No tests found
Test Common...
No tests found
No tests to run.
Finished at Wed Feb 28 10:41:55 AEST 2018
[Updated on: Thu, 01 March 2018 03:56] Report message to a moderator
FUDForum. Page generated in 0.03722 seconds
