implementing QualifiedNameProvider [message #1782012] |
Thu, 15 February 2018 23:53 |
Ruchika Kumar Messages: 50 Registered: January 2017 |
Member |
I'm having trouble with using and implementing my own QualifiedNameProvider to reference model elements without a name attribute for cross-referencing. I have looked online for resources, such as:
https://christiandietrich.wordpress.com/tag/iqualifiednameprovider/
https://stackoverflow.com/questions/10316112/xtext-cross-reference-using-custom-terminal-rule
https://www.eclipse.org/forums/index.php/t/1076818/
https://www.eclipse.org/forums/index.php/t/172914/
Unfortunately, I am still stuck after two days of tryng to find the bug. I tried to simplify and asbtract the problem from my main project as best I can to facilitate debugging. Hopefully, you can help me.
First off, the grammar:
grammar org.xtext.example.mydsl2.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl2/MyDsl"
Model:
(components+=Component | gates+=Gate)*
(connections += Connection)*
(interactions+=Interaction)*
Component:
'component' name=ID ';'
Gate:
'gate' name=ID ';'
Connection:
'connect' gateReferences+=GateReference 'to' gateReferences+=GateReference ';'
GateReference:
component=[Component] '.' gate=[Gate]
Interaction:
source=[GateReference | FQN] 'sends' value=INT 'to' target=[GateReference | FQN] ';'
FQN:
ID ('.' ID)*
Now, the toy example:
component c1;
component c2;
gate g1;
connect c1.g1 to c2.g1;
c1.g1 sends 5 to c2.g1;
In the textual connection specification, it finds and underlines errors in above, but suggests exactly those same names as quick fixes. See attached images for more information.
To fix the problem, I would like to reference a GateReference in an Interaction with the following name : componentName.gateName
To go about this, I tried defining my own QualifiedNameProvider, shown below:
package org.xtext.example.mydsl2.scoping;
import org.eclipse.xtext.naming.DefaultDeclarativeQualifiedNameProvider;
import org.eclipse.xtext.naming.QualifiedName;
import org.xtext.example.mydsl2.myDsl.GateReference;
public class MyQNProvider extends DefaultDeclarativeQualifiedNameProvider {
protected QualifiedName qualifiedName(GateReference gateReference) {
return QualifiedName.create(gateReference.getComponent().getName(), gateReference.getGate().getName());
Updated the RuntimeModule as well:
package org.xtext.example.mydsl2;
import org.eclipse.xtext.naming.IQualifiedNameProvider;
import org.xtext.example.mydsl2.scoping.MyQNProvider;
* Use this class to register components to be used at runtime / without the Equinox extension registry.
public class MyDslRuntimeModule extends AbstractMyDslRuntimeModule {
public Class<? extends IQualifiedNameProvider> bindIQualifiedNameProvider() {
return MyQNProvider.class;
I implemented a scope for the elements to see if that was part of the problem:
* generated by Xtext 2.12.0
import java.util.List;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EReference;
import org.eclipse.xtext.EcoreUtil2;
import org.eclipse.xtext.scoping.IScope;
import org.eclipse.xtext.scoping.Scopes;
import org.xtext.example.mydsl2.myDsl.MyDslPackage;
import com.google.inject.Inject;
* This class contains custom scoping description.
* See https://www.eclipse.org/Xtext/documentation/303_runtime_concepts.html#scoping
* on how and when to use it.
public class MyDslScopeProvider extends AbstractMyDslScopeProvider {
@Inject
MyQNProvider nameProvider;
public IScope getScope(EObject context, EReference reference) {
if (context instanceof Interaction &&
(reference == MyDslPackage.Literals.INTERACTION__SOURCE || reference == MyDslPackage.Literals.INTERACTION__TARGET)) {
EObject root = EcoreUtil2.getRootContainer(context);
return Scopes.scopeFor(EcoreUtil2.getAllContentsOfType(root, GateReference.class), nameProvider, IScope.NULLSCOPE);
return super.getScope(context, reference);
Alas, the code shown above doesn't work. I also receive this worker error:
2238 [Worker-1] ERROR org.eclipse.xtext.linking.lazy.LazyLinkingResource - Cyclic resolution of lazy links : GateReference.component->GateReference.component in resource 'platform:/resource/testProject/src/src_gen/test.mydsl2'.
org.eclipse.xtext.linking.lazy.LazyLinkingResource$CyclicLinkingException: Cyclic resolution of lazy links : GateReference.component->GateReference.component in resource 'platform:/resource/testProject/src/src_gen/test.mydsl2'.
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.handleCyclicResolution(LazyLinkingResource.java:302)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:240)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:222)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:201)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:261)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1477)
at org.xtext.example.mydsl2.myDsl.impl.GateReferenceImpl.getComponent(GateReferenceImpl.java:86)
at org.xtext.example.mydsl2.scoping.MyQNProvider.qualifiedName(MyQNProvider.java:10)
at sun.reflect.GeneratedMethodAccessor40.invoke(Unknown Source)
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:302)
at org.eclipse.xtext.naming.DefaultDeclarativeQualifiedNameProvider$2.get(DefaultDeclarativeQualifiedNameProvider.java:64)
at org.eclipse.xtext.naming.DefaultDeclarativeQualifiedNameProvider$2.get(DefaultDeclarativeQualifiedNameProvider.java:59)
at org.eclipse.xtext.util.OnChangeEvictingCache.get(OnChangeEvictingCache.java:77)
at org.eclipse.xtext.naming.DefaultDeclarativeQualifiedNameProvider.getFullyQualifiedName(DefaultDeclarativeQualifiedNameProvider.java:59)
at org.eclipse.xtext.naming.IQualifiedNameProvider$AbstractImpl.apply(IQualifiedNameProvider.java:32)
at org.eclipse.xtext.naming.IQualifiedNameProvider$AbstractImpl.apply(IQualifiedNameProvider.java:29)
at org.eclipse.xtext.scoping.Scopes$2.apply(Scopes.java:93)
at org.eclipse.xtext.scoping.Scopes$2.apply(Scopes.java:90)
at com.google.common.collect.Iterators$7.transform(Iterators.java:750)
at com.google.common.collect.TransformedIterator.next(TransformedIterator.java:47)
at com.google.common.collect.Iterators$6.computeNext(Iterators.java:616)
at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:145)
at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:140)
at org.eclipse.xtext.scoping.impl.MultimapBasedSelectable.setExportedObjects(MultimapBasedSelectable.java:106)
at org.eclipse.xtext.scoping.impl.MultimapBasedSelectable.<init>(MultimapBasedSelectable.java:36)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.internalGetAllDescriptions(ImportedNamespaceAwareLocalScopeProvider.java:243)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider$2.get(ImportedNamespaceAwareLocalScopeProvider.java:230)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider$2.get(ImportedNamespaceAwareLocalScopeProvider.java:227)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.getAllDescriptions(ImportedNamespaceAwareLocalScopeProvider.java:227)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.getResourceScope(ImportedNamespaceAwareLocalScopeProvider.java:120)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.getResourceScope(ImportedNamespaceAwareLocalScopeProvider.java:109)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.getScope(ImportedNamespaceAwareLocalScopeProvider.java:97)
at org.eclipse.xtext.scoping.impl.ImportedNamespaceAwareLocalScopeProvider.getScope(ImportedNamespaceAwareLocalScopeProvider.java:95)
at org.eclipse.xtext.scoping.impl.DelegatingScopeProvider.delegateGetScope(DelegatingScopeProvider.java:42)
at org.eclipse.xtext.scoping.impl.DelegatingScopeProvider.getScope(DelegatingScopeProvider.java:38)
at org.xtext.example.mydsl2.scoping.MyDslScopeProvider.getScope(MyDslScopeProvider.java:36)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getScope(DefaultLinkingService.java:59)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:120)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:247)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doResolveLazyCrossReference(LazyLinkingResource.java:189)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReference(LazyLinkingResource.java:148)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReferences(LazyLinkingResource.java:134)
at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:498)
at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.postParse(XtextDocumentReconcileStrategy.java:175)
at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.doReconcile(XtextDocumentReconcileStrategy.java:153)
at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.reconcile(XtextDocumentReconcileStrategy.java:67)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.doRun(XtextReconciler.java:449)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.access$3(XtextReconciler.java:429)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler$1.process(XtextReconciler.java:363)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler$1.process(XtextReconciler.java:1)
at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:37)
at org.eclipse.xtext.resource.OutdatedStateManager.exec(OutdatedStateManager.java:91)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.modify(XtextDocument.java:428)
at org.eclipse.xtext.ui.editor.model.XtextDocument.internalModify(XtextDocument.java:162)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.run(XtextReconciler.java:360)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
A note: in my original project, I'm importing an ecore model and am not allowed to change it in any way. I'm quite limited in terms of allowable grammar specifications, so if is possible to
fix the problem without changing the grammar, that would be awesome.
Thanks in advance
Attachment: error1.png
(Size: 6.34KB, Downloaded 79 times) -
Attachment: error2.png
(Size: 6.78KB, Downloaded 75 times)
[Updated on: Thu, 15 February 2018 23:57] Report message to a moderator
Re: implementing QualifiedNameProvider [message #1782405 is a reply to message #1782401] |
Thu, 22 February 2018 17:42 |
the segements you call QualifiedNAme.create(segment1,...,segementn) may not contain "."
String gateReferenceText1 = NodeModelUtils.findNodesForFeature(gateReference, MyDslPackage.Literals.GATE_REFERENCE__COMPONENT).get(0).getText().trim();
String gateReferenceText2 = NodeModelUtils.findNodesForFeature(gateReference, MyDslPackage.Literals.GATE_REFERENCE__GATE).get(0).getText().trim();
return QualifiedName.create(gateReferenceText1,gateReferenceText2);
or
String gateReferenceText = NodeModelUtils.getNode(gateReference).getText().trim();
return getConverter().toQualifiedName(gateReferenceText);
Twitter : @chrdietrich
FUDForum. Page generated in 0.03512 seconds
