Home » Eclipse Projects » EGit / JGit » JGit Find Merge Base
JGit Find Merge Base [message #1781943] Wed, 14 February 2018 20:54 Go to next message
Ricky Veach is currently offline Ricky VeachFriend
I am trying to find the common ancestor between any 2 commits, also known as the merge base.
I tried using code like the one found at https://stackoverflow.com/a/26436588/1016482 , but it seems to fail in a specific situation.
If I give it 2 branches, where one branch has diverged with many new commits, it returns the correct merge base commit.
However, if I give it a commit and the commit's parent, it doesn't return the commit's parent as the merge base. Instead it returns the commit 2 parents from that.
Example:
Code:
	public static RevCommit getCommonAncestor(Repository repository, RevCommit commit1,
			RevCommit commit2) {
		RevWalk walk = null;
		try {
			walk = new RevWalk(repository);
			walk.setRevFilter(RevFilter.MERGE_BASE);
			walk.markStart(commit1);
			walk.markStart(commit2);
			final RevCommit base = walk.next();
			if ((base != null) && (walk.next() == null)) {
				return base;
		catch (IOException e) {
			e.printStackTrace();
		finally {
			if (walk != null) {
				walk.reset();
				walk.close();
				walk.dispose();
		return null;
Repository:
Head -> A -> B -> C -> D
So Commit A is the parent of Head and so on.
Expected Result of `getCommonAncestor(repository, CommitA, HEAD)` should be commit A.
What is actually returned is commit C.
Is there something I am doing wrong? Can I not use merge base in this circumstance or is this a bug?
I am using `org.eclipse.jgit` version `4.10.0.201712302008-r`.
[Updated on: Wed, 14 February 2018 22:07]
Report message to a moderator
Re: JGit Find Merge Base [message #1781945 is a reply to message #1781943] Wed, 14 February 2018 22:51 Go to previous messageGo to next message
I don't know why, but the method works correctly when I re-parse the commits again before trying the merge base.
			walk = new RevWalk(git.getRepository());
			commit1 = walk.parseCommit(commit1);
			commit2 = walk.parseCommit(commit2);
The only thing I did with the commits outside the method was retrieve them via another method.
	public static RevCommit getCommit(Repository repository, String commitId) {
		RevCommit result = null;
		try {
			final ObjectId commitObject = repository.resolve(commitId);
			if (commitObject != null) {
				result = walk.parseCommit(commitObject);
		catch (RevisionSyntaxException | IOException e) {
		finally {
			if (walk != null) {
				walk.close();
				walk.dispose();
		return result;
Can any one explain if I am doing something wrong that would require this extra code?
Re: JGit Find Merge Base [message #1782580 is a reply to message #1781945] Mon, 26 February 2018 16:50 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
JGit only knows the objectId of objects which weren't parsed yet. Only when you parse them jgit gets access to the object's data
Re: JGit Find Merge Base [message #1782581 is a reply to message #1782580] Mon, 26 February 2018 16:53 Go to previous message
RevCommits need to be produced by the same RevWalk instance otherwise you can't compare them
Previous Topic:EGit auto capitalize branch names
Next Topic:JGit DiffCommand result is different from command line Git
Current Time: Thu Oct 01 13:26:39 GMT 2020
Powered by FUDForum. Page generated in 0.01925 seconds
