Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Build Forte using libiec61850(Build Forte using libiec61850)
Build Forte using libiec61850 [message #1781932] Wed, 14 February 2018 17:43 Go to next message
Felipe Nunes is currently offline Felipe NunesFriend
i have used the http://libiec61850.com version libiec61850-1.1.1.tgz
however, I do not know which parameters to use in the SIFB for use of the GOOSE protocol.
Re: Build Forte using libiec61850 [message #1781942 is a reply to message #1781932] Wed, 14 February 2018 20:28 Go to previous message
Alois Zoitl is currently offline Alois ZoitlFriend
this strongly depends what you would like to do with IEC 61850 and how to represent this in the SIFB. Therfore it is very hard to answer this question. Maybe the section on the communication architecture of FORTE can be a starting point for you.
However please note that the license of libiec61850 is incompatible with the EPL used by 4diac.
Previous Topic:Commentary Feature
Next Topic:FBRT/UI/HMI in 1.9.0
Current Time: Tue Jan 26 19:37:12 GMT 2021
Powered by FUDForum. Page generated in 0.02080 seconds
