Re: Where to find source for older versions [message #1781798 is a reply to message #1781796] |
Tue, 13 February 2018 11:09 |
Hi Sandeep,
you don't necessarily need the source to compile plugins. However it is some work and I only saw that it is possible but never did it using Eclipse Target platform mechanism. Nonetheless the old source code is still in our old mercurial repository [1]. By invoking:
hg clone http://hg.code.sf.net/p/fordiac/fordiac-ide fordiac-fordiac-ide
you should get it. You need to switch to the 1.8.x branch. Then hopefully these plugins should compile again.
I was not aware that this code from Luca is also available. It would be great to have that also on latest 1.9.0. Unfortunately this will be quite some work. Not only the namespace of our plugins changed to the eclipse namespace, but with the code cleanup some of the API completely changed. On the other hand with this cleanup plugins like the ones from luka can now be implemented much easier.
BTW you may want to know that Luca gave us his communication generation plugin and this is also part of 4diac 1.9.0-
Alois
[1] https://sourceforge.net/p/fordiac/fordiac-ide/ci/default/tree/
Re: Where to find source for older versions [message #1781808 is a reply to message #1781804] |
Tue, 13 February 2018 12:33 |
Hi Sandeep,
The core changelog would be that we removed the UI Model. So everything deriving from View. Based on that we changed nearly every plugin and cleaned-up all over the place (roughly 1000 commits). So I don't know how to provide a somehow usable changelog.
But if you are down to 20 issues. I think it is pretty quick to fix. I could offer you a shared screen-session with goto-meeting or skype and we fix it together. If you have time I would be available today in the afternoon.
Alois
Re: Where to find source for older versions [message #1781809 is a reply to message #1781807] |
Tue, 13 February 2018 12:36 |
I just noticed that the Elcipse forum does not nest replies correctly. So please put my last message to your first message. This is now for the
org.fordiac.ide.typeexport.FbtExporter.saveAsFBTFile()
issue.
The type export and import has been moved to the models plugin somewhere around 1.3 or 1.4. So you should find this class and this method in the models plugin:
fordiac-ide\plugins\org.fordiac.ide.model\src\org\fordiac\ide\typeexport
However you may have to provide an IFile now.
FUDForum. Page generated in 0.02991 seconds
