Home » Language IDEs » Java Development Tools (JDT) » Seeking useful plugin documentation(Each one I've viewed leads to a dead end, either a crash of insufficient information)
Seeking useful plugin documentation [message #1781736] |
Mon, 12 February 2018 19:44 |
Jerry Miller Messages: 6 Registered: March 2014 |
I'm told I can test Eclipse plugins (not what I eventually want to develop, but that's what the intro examples recommend) by debugging within Eclipse apparently running another instance of Eclipse with the plugin, if I've read it correctly.
But lo and behold, I get an error dump complaining about a missing component that I can't even find, given the haphazard way I discover alternative views of the project. Some page tells me to delete a lock file without telling me where to find it, but it doesn't help.
Later, I find a doc that says to create a zip file to expand into a plugin directory, which I have yet to look for, because the next step tells me to create and run build.xml, which creates a @dot directory and still no zip file!
In addition, the doc in question tells me to click the Export... button on figure 2 to get to figure 3, only it never told me how to get to figure 2!!!
Re: Seeking useful plugin documentation [message #1781740 is a reply to message #1781739] |
Mon, 12 February 2018 21:02 |
If I'm able to track down the page I found on Friday that got me as far as crashing, or the one after it that told me to delete a lock file, I'll post that. Meanwhile, I can't even find the one one from today, because I lost it in the hassle to find this forum, but I believe it was an Eclipse document.
The only page I still have open is another one that gave me information that crashed with a port that couldn't be accessed, without telling me why I needed a port. (Since -port does not appear to be a Java option, I'm guessing it's an obscure Eclipse one. Anyway, it was using 22, the ssh port, but changing it didn't help, and omitting it caused a complaint:
https://stackoverflow.com/questions/255370/automating-unit-tests-junit-for-eclipse-plugin-development
Re: Seeking useful plugin documentation [message #1781741 is a reply to message #1781740] |
Mon, 12 February 2018 21:06 |
On the other hand, what I'm asking should be fairly straightforward. Where can I find a complete, accurate documentation of the creation and testing of plug-ins, complete with an explanation of why I'm doing what I'm told to do, so I know what to try when it doesn't work?
One thing I can tell you about the page I read on Friday is that it created what it called a "helloworld" example that, as far as I could see, didn't even output "Hello world!" in any way, shape, or form, let alone do anything else--not very useful!
I'm pretty sure it wasn't this, which I just found in a search, but I'm bookmarking it as what I hope will be a less abortive attempt than any I've encountered up to now:
https://www.eclipse.org/articles/Article-Your%20First%20Plug-in/YourFirstPlugin.html
[Updated on: Mon, 12 February 2018 21:17] Report message to a moderator
Re: Seeking useful plugin documentation [message #1781743 is a reply to message #1781741] |
Mon, 12 February 2018 21:43 |
Stephan Herrmann Messages: 1853 Registered: July 2009 |
Eclipse, like any software, is evolving technology, so the tutorial "YourFirstPlugin.html" doesn't look like a good candidate, because its last modification dates 15 years back!
In fact, that modification was the addition of: "Editor's note: Sept. 2003 - This article has been retired from service. ".
A better guess would be this (last edit 2016): http://www.vogella.com/tutorials/EclipsePlugin/article.html
Anyway, there are several others on the web, too, just make sure to check it's recency. It should at the very least cover Eclipse 3.x,
because the nature of plugins has changed significantly between 2.x and 3.x.
Re: Seeking useful plugin documentation [message #1781832 is a reply to message #1781743] |
Tue, 13 February 2018 17:12 |
Gerald Miller Messages: 3 Registered: February 2018 |
!SESSION 2018-02-13 12:10:14.448 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_102
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -application garbage.application
Command-line arguments: -application garbage.application -data C:\Users\gerald.miller\plugintest/../runtime-garbage.application -dev file:C:/Users/gerald.miller/plugintest/.metadata/.plugins/org.eclipse.pde.core/garbage.application/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.ui.workbench 4 0 2018-02-13 12:10:15.041
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ui.workbench [7]
Unresolved requirement: Import-Package: org.eclipse.e4.ui.internal.workbench.swt
-> Export-Package: org.eclipse.e4.ui.internal.workbench.swt; bundle-symbolic-name="org.eclipse.e4.ui.workbench.swt"; bundle-version="0.14.0.v20160523-1900"; version="0.0.0"; x-friends:="org.eclipse.e4.ui.workbench.addons.swt,org.eclipse.e4.ui.workbench.renderers.swt,org.eclipse.ui.workbench"
org.eclipse.e4.ui.workbench.swt [20]
Unresolved requirement: Require-Capability: osgi.extender; filter:="(&(osgi.extender=osgi.component)(version>=1.2)(!(version>=2.0)))"
Unresolved requirement: Import-Package: org.eclipse.e4.ui.internal.workbench.renderers.swt
-> Export-Package: org.eclipse.e4.ui.internal.workbench.renderers.swt; bundle-symbolic-name="org.eclipse.e4.ui.workbench.renderers.swt"; bundle-version="0.14.0.v20160525-0940"; version="0.0.0"; x-friends:="org.eclipse.ui.workbench"
org.eclipse.e4.ui.workbench.renderers.swt [19]
Unresolved requirement: Require-Bundle: org.eclipse.e4.ui.workbench.swt; bundle-version="0.9.0"
-> Bundle-SymbolicName: org.eclipse.e4.ui.workbench.swt; bundle-version="0.14.0.v20160523-1900"; singleton:="true"
at org.eclipse.osgi.container.Module.start(Module.java:444)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1599)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.e4.ui.workbench.addons.swt 4 0 2018-02-13 12:10:15.048
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.e4.ui.workbench.addons.swt [13]
Unresolved requirement: Require-Bundle: org.eclipse.e4.ui.workbench.renderers.swt; bundle-version="0.9.1"
-> Bundle-SymbolicName: org.eclipse.e4.ui.workbench.renderers.swt; bundle-version="0.14.0.v20160525-0940"; singleton:="true"
!ENTRY org.eclipse.e4.ui.workbench.renderers.swt 4 0 2018-02-13 12:10:15.055
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.e4.ui.workbench.renderers.swt [19]
!ENTRY org.eclipse.e4.ui.workbench.swt 4 0 2018-02-13 12:10:15.060
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.e4.ui.workbench.swt [20]
!ENTRY org.eclipse.ui 4 0 2018-02-13 12:10:15.065
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.ui [37]
Unresolved requirement: Require-Bundle: org.eclipse.ui.workbench; bundle-version="[3.105.0,4.0.0)"; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.ui.workbench; bundle-version="3.108.0.v20160602-1232"; singleton:="true"
!ENTRY garbage 4 0 2018-02-13 12:10:15.070
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: garbage [68]
-> Bundle-SymbolicName: org.eclipse.ui; bundle-version="3.108.0.v20160518-1929"; singleton:="true"
org.eclipse.ui [37]
!ENTRY org.eclipse.e4.ui.workbench.swt 2 0 2018-02-13 12:10:15.322
!MESSAGE Could not resolve module: org.eclipse.e4.ui.workbench.swt [20]
!ENTRY org.eclipse.ui.workbench 2 0 2018-02-13 12:10:15.328
!MESSAGE Could not resolve module: org.eclipse.ui.workbench [7]
!ENTRY org.eclipse.e4.ui.workbench.renderers.swt 2 0 2018-02-13 12:10:15.333
!MESSAGE Could not resolve module: org.eclipse.e4.ui.workbench.renderers.swt [19]
!ENTRY org.eclipse.e4.ui.workbench.addons.swt 2 0 2018-02-13 12:10:15.340
!MESSAGE Could not resolve module: org.eclipse.e4.ui.workbench.addons.swt [13]
!ENTRY org.eclipse.ui 2 0 2018-02-13 12:10:15.345
!MESSAGE Could not resolve module: org.eclipse.ui [37]
!ENTRY garbage 2 0 2018-02-13 12:10:15.350
!MESSAGE Could not resolve module: garbage [68]
org.eclipse.ui [37]
!ENTRY org.eclipse.osgi 4 0 2018-02-13 12:10:15.355
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "garbage.application" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.equinox.app.error.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
An error has occurred. See the log file
C:\Users\gerald.miller\plugintest\.metadata\.plugins\org.eclipse.pde.core\garbage.application\1518541814736.log.
Current Time: Thu Apr 25 09:13:00 GMT 2024
Powered by FUDForum. Page generated in 0.03706 seconds
