Home » Modeling » Papyrus » SynchMessage from Sequence diagram does not appear in the class diagramm(SynchMessage from Sequence diagram does not appear in the class diagramm)
SynchMessage from Sequence diagram does not appear in the class diagramm [message #1781722] Mon, 12 February 2018 14:51 Go to next message
Abdel Ame is currently offline Abdel AmeFriend
Hello everybody,
i have eclipse oxygen jee with papyrus installed.
I have created class diagramm and sequence digram in the same model.
The sequence diagram uses the instances from the class diagram.
The problem is:
when I create one synchMessage on the sequence diagram I do not see this operation on the class diagram for the specified class (right click -> show hide content).
Thanks a lot for every help
Re: SynchMessage from Sequence diagram does not appear in the class diagramm [message #1781940 is a reply to message #1781722] Wed, 14 February 2018 19:54 Go to previous message
Carsten Pitz is currently offline Carsten PitzFriend
Hi Abdel,
A class diagram is to visualize structure. A synchronize message expresses a behavior. That is why Papyrus strictly adhering to the OMG UML specification does not support messages on class diagrams.
Best regards
Carsten
Previous Topic:Generate profile from a domain model
Next Topic:[Informative Message] Default naming strategies changes for Papyrus Oxygen.3
Current Time: Mon Aug 10 16:30:09 GMT 2020
Powered by FUDForum. Page generated in 0.03776 seconds
