Home » Archived » Eclipse SmartHome » Eclipse SmartHome karaf Feature verification.......FAILURE(Eclipse SmartHome karaf Feature verification.......FAILURE)
Eclipse SmartHome karaf Feature verification.......FAILURE [message #1781719] Mon, 12 February 2018 14:18 Go to next message
SRIRAMACHANDRA MACHARAYYA GANGUMALLA is currently offline SRIRAMACHANDRA MACHARAYYA GANGUMALLAFriend
I am very new to SmartHome and when I was trying to package with maven I was facing this issue. Please find the below attached
  • Attachment: error.txt
    (Size: 30.11KB, Downloaded 196 times)
Re: Eclipse SmartHome karaf Feature verification.......FAILURE [message #1782035 is a reply to message #1781719] Fri, 16 February 2018 10:15 Go to previous messageGo to next message
Stefan Triller is currently offline Stefan TrillerFriend
Looks like a temporary problem with a server providing the dependency. Have you tried it again at a different time?
Re: Eclipse SmartHome karaf Feature verification.......FAILURE [message #1782216 is a reply to message #1782035] Tue, 20 February 2018 14:07 Go to previous messageGo to next message
Chiranjeevi B is currently offline Chiranjeevi BFriend
Hello stefan,
I have tried it with different time but i am facing same issue.
Re: Eclipse SmartHome karaf Feature verification.......FAILURE [message #1782533 is a reply to message #1782216] Mon, 26 February 2018 08:28 Go to previous messageGo to next message
Markus Rathgeb is currently offline Markus RathgebFriend
* Could not find artifact org.eclipse.smarthome:esh-tp:xml:features:0.10.0-SNAPSHOT
* Could not find artifact org.eclipse.smarthome:esh-ext:xml:features:0.10.0-SNAPSHOT
The artifacts itself should be part of the build.
They reside in that directories (relative to the root one):
* featres/karaf/esh-tp
* featres/karaf/esh-ext
Re: Eclipse SmartHome karaf Feature verification.......FAILURE [message #1782557 is a reply to message #1782533] Mon, 26 February 2018 13:08 Go to previous messageGo to next message
WRT to https://github.com/eclipse/smarthome/pull/2081#issuecomment-368468017 you need to understand
  • OSGi requirements and capabilities concept
  • Karaf features
Message: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=esh-persistence-h2; type=karaf.feature; version=0.10.0.SNAPSHOT; filter:="(&(osgi.identity=esh-persistence-h2)(type=karaf.feature)(version>=0.10.0.SNAPSHOT))" [caused by: Unable to resolve esh-persistence-h2/0.10.0.SNAPSHOT: missing requirement [esh-persistence-h2/0.10.0.SNAPSHOT] osgi.identity; osgi.identity=org.h2; type=osgi.bundle; version="[1.3.176,1.3.176]"; resolution:=mandatory [caused by: Unable to resolve org.h2/1.3.176: missing requirement [org.h2/1.3.176] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.osgi.service.jdbc)(version>=1.0.0))"]]
Just a little bit formatted:
caused by:
caused by:
Re: Eclipse SmartHome karaf Feature verification.......FAILURE [message #1782784 is a reply to message #1782557] Thu, 01 March 2018 11:29 Go to previous messageGo to next message
Hello sir,
i am getting : KarafFeatureCheck will be skipped. Could not find file features/openhab-addons/src/main/feature/feature.xml, i assume this is build issue am not getting what to do. please guide me what need to do i have attached the file please check it once, thank you.
  • Attachment: logfile
    (Size: 145.31KB, Downloaded 216 times)
Re: Eclipse SmartHome karaf Feature verification.......FAILURE [message #1782785 is a reply to message #1782557] Thu, 01 March 2018 11:33 Go to previous messageGo to next message
Hello sir,
Re: Eclipse SmartHome karaf Feature verification.......FAILURE [message #1782813 is a reply to message #1782785] Thu, 01 March 2018 19:23 Go to previous messageGo to next message
[WARNING] KarafFeatureCheck will be skipped. Could not find file features/openhab-addons/src/main/feature/feature.xml
The KarafFeatureCheck warning is caused by the SAT plugin and you can ignore them.
I will inform the maintainer of the plugin.
The build issue is the same as before that I already tried to format a little bit better.
It is about unsatisfied requirements.
Re: Eclipse SmartHome karaf Feature verification.......FAILURE [message #1782814 is a reply to message #1782785] Thu, 01 March 2018 19:23 Go to previous message
No Message Body
[Updated on: Thu, 01 March 2018 19:24]
Report message to a moderator
Previous Topic:Eclipse SmartHome karaf Feature verification.......FAILURE
Next Topic:ESH Console extensions
Current Time: Mon Jan 20 01:55:16 GMT 2025
Powered by FUDForum. Page generated in 0.04035 seconds
