Birt error on redhat 7 when report contins chart [message #1781712] |
Mon, 12 February 2018 13:53 |
ANDRE SEJOURNET Messages: 2 Registered: February 2018 |
I run Birt viewer 4.4.2 on redhat 7.2 using Tomcat 8.0.39.
Java :
openjdk version "1.8.0_91"
OpenJDK Runtime Environment (build 1.8.0_91-b14)
OpenJDK 64-Bit Server VM (build 25.91-b14, mixed mode)
It works fine for all reports except those containing charts.
This is the error I get when a report contains a chart :
- org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
AxisFault
faultCode: {...}Server.userException
faultSubcode:
faultString: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
faultActor:
faultNode:
faultDetail:
{...xml.apache.org/axis/}stackTrace:org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
at org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1115)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:943)
at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtRunAndRenderActionHandler.__execute(BirtRunAndRenderActionHandler.java:76)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.presentation.aggregation.layout.RunFragment.doService(RunFragment.java:120)
at org.eclipse.birt.report.presentation.aggregation.layout.FramesetFragment.service(FramesetFragment.java:86)
at org.eclipse.birt.report.servlet.ViewerServlet.__doGet(ViewerServlet.java:181)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doGet(BirtSoapMessageDispatcherServlet.java:160)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:622)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:212)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:509)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1104)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:684)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1520)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1476)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2396)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:191)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:937)
... 35 more
Caused by: java.lang.NoClassDefFoundError: org.eclipse.birt.chart.device.image.JavaxImageIOWriter
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at org.eclipse.birt.core.framework.jar.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:46)
at org.eclipse.birt.core.framework.eclipse.EclipseConfigurationElement.createExecutableExtension(EclipseConfigurationElement.java:35)
at org.eclipse.birt.chart.util.PluginSettings.getPluginXmlObject(PluginSettings.java:1258)
at org.eclipse.birt.chart.util.PluginSettings.getDevice(PluginSettings.java:638)
at org.eclipse.birt.chart.api.ChartEngine.getRenderer(ChartEngine.java:119)
at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationBase.prepareDeviceRenderer(ChartReportItemPresentationBase.java:1223)
at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationBase.generateRenderObject(ChartReportItemPresentationBase.java:972)
at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationBase.onRowSets(ChartReportItemPresentationBase.java:905)
at org.eclipse.birt.chart.reportitem.ChartReportItemPresentationProxy.onRowSets(ChartReportItemPresentationProxy.java:108)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.processExtendedContent(LocalizedContentVisitor.java:1100)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.localizeForeign(LocalizedContentVisitor.java:602)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.localize(LocalizedContentVisitor.java:176)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:37)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.traverse(HTMLAbstractLM.java:441)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.traverse(HTMLAbstractLM.java:442)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.handleVisibility(HTMLAbstractLM.java:374)
at org.eclipse.birt.report.engine.layout.html.HTMLRowLM.handleVisibility(HTMLRowLM.java:33)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:123)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:71)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLRepeatHeaderLM.layoutChildren(HTMLRepeatHeaderLM.java:46)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:181)
... 37 more
{...xml.apache.org/axis/}hostname:srvrhel7bkp.ao.local
{}:org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
... 35 more
... 37 more
at org.apache.axis.AxisFault.makeFault(AxisFault.java:101)
at org.eclipse.birt.report.utility.BirtUtility.makeAxisFault(BirtUtility.java:777)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:94)
Caused by: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
... 32 more
... 35 more
... 37 more
I look at several posts, but I found only old ones.
Thanks in advance.
FUDForum. Page generated in 0.03562 seconds
