Home » Newcomers » Newcomers » On using multiple IDE's(Can I use the same based with multiple environments)
On using multiple IDE's [message #1781673] Mon, 12 February 2018 00:08 Go to next message
Henry Stock is currently offline Henry StockFriend
On the downloads page, there are installers for multiple IDE environments like C++, PHP, Java, Javascript, modeling, etc.
My guess is that there is overlap in what is installed in each case. My question is whether or not it is possible to install one base and be able to select the desired IDE environment, C++, or PHP, or modeling, etc. without installing duplicate code.
For example, can I install everything under one directory c:\eclipse?
If so, then what do I have to modify so that I can choose a specific environment when I start up?
Re: On using multiple IDE's [message #1781713 is a reply to message #1781673] Mon, 12 February 2018 13:59 Go to previous messageGo to next message
Charles Rivet is currently offline Charles RivetFriend
Hy Henry,
You can do this by using the Eclipse Installer https://wiki.eclipse.org/Eclipse_Installer and making sure to check the Bundle pool capability. This will place all the plugins in one location. You still need to select a base package, but then you can add any other project on the second dialog.
You can read more about bundle pool at: https://help.eclipse.org/mars/topic/org.eclipse.oomph.setup.doc/html/concepts/DocBundlePool.html
/Charles Rivet
Re: On using multiple IDE's [message #1781714 is a reply to message #1781673] Mon, 12 February 2018 13:59 Go to previous messageGo to next message
Hy Henry,
/Charles Rivet
Re: On using multiple IDE's [message #1781715 is a reply to message #1781673] Mon, 12 February 2018 14:00 Go to previous message
Hy Henry,
/Charles Rivet
Previous Topic:Cannot find javadocs in Eclipse/Java
Next Topic:Eclipse doesn't Detect gfortran on Linux
Current Time: Sun Jan 17 01:20:53 GMT 2021
Powered by FUDForum. Page generated in 0.03158 seconds
