Re: Build xtext with maven [message #1781657 is a reply to message #1781654] |
Sun, 11 February 2018 08:43 |
Xtext 210 is quite old so I cannot support you with building it
Anyway. You mix up two things.
(1) building single plugins and installing them to a maven repo
(2) building a p2 repository and make it consumable and actually consume it from another p2 build
That you are not doing is (2)
Twitter : @chrdietrich
Re: Build xtext with maven [message #1781660 is a reply to message #1781658] |
Sun, 11 February 2018 09:00 |
if xtext 2.10 uses tycho to build the repositories look out for a project with packaging <packaging>eclipse-repository</packaging>
but afaik huge parts of xtext 2.10 were built with buckminister and i have no idea how to get that running (maybe you can do a full build of all by calling some ant files
(see How to Build an Xtext p2 Repository in the readme as well)
inside the other projects build there are either p2 repositories configured in poms (with type p2) or inside .target files.
is there a reason you insist to use xtext 2.10
FUDForum. Page generated in 0.02358 seconds
