Home » Eclipse Projects » Linux Tools Project » Valgrind with MacOS Sierra - cannot create symlink( System Integrity Protection prevents symlink to hardcoded path)
Valgrind with MacOS Sierra - cannot create symlink [message #1781308] Mon, 05 February 2018 21:29 Go to next message
David Antliff is currently offline David AntliffFriend
On MacOS Sierra, it is common for users to install valgrind via Brew. This installs the binary as /usr/local/bin/valgrind.
The Linux Tools plugin looks for valgrind at /usr/bin/valgrind, and does not search /usr/local/bin or allow the user to specify a custom path as far as I can tell.
The Linux Tools documentation says to create a symlink in /usr/bin. Apart from the `ln` command being incorrect (the parameters are backwards), this is not possible in Sierra due to System Integrity Protection (SIP).
SIP prevents any modifications to /usr/bin even by the root user. It is therefore impossible to create a /usr/bin/valgrind symlink even as root, without disabling SIP, and I'd suggest that disabling SIP is a very bad idea.
So I think we're left in a situation where valgrind can be run from the command line, but the Linux Tools plugin within Eclipse is unable to be used.
Is this an accurate assessment or is there a way around this that I don't know yet?
Re: Valgrind with MacOS Sierra - cannot create symlink [message #1781309 is a reply to message #1781308] Mon, 05 February 2018 21:32 Go to previous messageGo to next message
For anyone coming across this in future, I've come across a per-project workaround that seems to work:
Open the project properties and select "Linux Tools Path", then select "Prepend string to PATH" and choose "Custom", then add the text "/usr/local/bin" to the text field.
This should enable the Linux Tools plugin to find the valgrind binary in /usr/local/bin.
[Updated on: Mon, 05 February 2018 21:34]
Report message to a moderator
Re: Valgrind with MacOS Sierra - cannot create symlink [message #1781315 is a reply to message #1781308] Mon, 05 February 2018 23:03 Go to previous message
Jeff Johnston is currently offline Jeff JohnstonFriend
I think that section of the manual is out of date. Looking at the current code, I see no hard-coding of /usr/bin/valgrind. The ValgrindCommand class is just running "valgrind" and expecting it to be on the Path. I don't have a Mac system to test with, but did you already try putting /usr/local/bin on the path used to bring up your Eclipse?
Previous Topic:Linux Tools 6.2.0 for Oxygen.2 is released
Next Topic:Linux Tools 7.0.0 is released for Photon
Current Time: Mon Nov 30 20:48:42 GMT 2020
Powered by FUDForum. Page generated in 0.02206 seconds
