Re: New Papyrus Model Wizard Won't Close On Finish [message #1801675 is a reply to message #1801513] |
Thu, 24 January 2019 16:13 |
In order to analyse the problem it would be helpful to see an eventual error message (Show View -> Error log), seeing lots of question-marks is not. Other things to try out is to start with a fresh workspace and check whether the issue is reproducible there.
Besides of that, Papyrus on Eclipse Neon is no longer supported and you should (if possible) migrate to a newer version of Eclipse.
Re: New Papyrus Model Wizard Won't Close On Finish [message #1801861 is a reply to message #1801748] |
Mon, 28 January 2019 15:21 |
The problem is not reproducible in a standard neon installation (just tested with a fresh installation). I already suggested two things to try out. Another thing would be to make sure that only Papyrus itself and not the add-ons (extra-plugins) are installed. If you have an exception in the log, you should post it here - otherwise we can't help you.
FUDForum. Page generated in 0.02718 seconds
