Help setting up remote debugging with Eclipse and Xdebug [message #1781048] |
Wed, 31 January 2018 19:14 |
Steve _____ Messages: 48 Registered: April 2012 |
Member |
Client Side:
Eclipse for PHP Developers
Version: Oxygen.2 Release (4.7.2)
Build id: 20171218-0600
Redhat Enterprise Linux 6.9
java version "1.8.0_101"
Java(TM) SE Runtime Environment (build 1.8.0_101-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.101-b13, mixed mode)
PHP 5.6
No web server installed locall
Remote Server Where The PHP web app is
PHP 5.6.5
Zend Engine v2.6.0, Copyright (c) 1998-2014 Zend Technologies
with Zend OPcache v7.0.4-dev, Copyright (c) 1999-2014, by Zend Technologies
with Xdebug v2.2.7, Copyright (c) 2002-2015, by Derick Rethans
I have the above environment(s). I would like to debug a PHP web app on a remote server, without having to run (or have) a local copy of the site.
I found some instructions in the Eclipse Help Contents on doing this
http://127.0.0.1:40184/help/topic/org.eclipse.php.help/html/tasks/debugging/troubleshooting_remote_debugging/index.html?cp=9_3_19_6
However, the instructions are only for the Zend debugger. I'm not sure that the remote site ( see above ) I want to debug has the Zend debugger. It looks like it has the Xdebug debugger.
Are the instructions the same, or would I only have to alter the php.ini for the Zend Debugger?
Are there instructions for complete remote debugging with Eclipse and Xdebug only ( without needing anything locally )?
Thanks.
FUDForum. Page generated in 0.01970 seconds
