Home » Modeling » Papyrus » CSS help to show opaque behavior of internal transitions
CSS help to show opaque behavior of internal transitions [message #1781047] Wed, 31 January 2018 18:38 Go to next message
Leandro Francucci is currently offline Leandro FrancucciFriend
I use the following CSS rules succesfully for showing the opaque behavior (in C language) of several actions for a state machine diagram:
Transition > Label {
bodyCutLength: 128;
indicateParameters: true;
State > OpaqueBehavior { /* also it delete the label OpaqueBehavior */
bodyCutLength: 128;
However, it not working for internal transitions with opaque behavior (effect) as shown in the attached diagram.
index.php/fa/31964/0/
I have been searching for ways to do this in CSS but I cannot find the right selectors or parameters in the CSS documentation.
If anyone knows the right CSS terms please help me, thanks!
Re: CSS help to show opaque behavior of internal transitions [message #1783373 is a reply to message #1781047] Mon, 12 March 2018 13:07 Go to previous messageGo to next message
Yoann Farré is currently offline Yoann FarréFriend
I have not the answer but I'm also interested in this feature. Did you find the solution to display the OpaqueBehavior of an internal transition?
Yoann.
Re: CSS help to show opaque behavior of internal transitions [message #1783470 is a reply to message #1783373] Tue, 13 March 2018 13:26 Go to previous messageGo to next message
Hi Yoann,
Unfortunately not yet, but I expect for someone put some light on this issue.
Leandro.
Re: CSS help to show opaque behavior of internal transitions [message #1783579 is a reply to message #1783470] Wed, 14 March 2018 10:50 Go to previous messageGo to next message
Hi Leandro,
I found an option in preferences tables which can be helpful although not perfect.
Window > Preferences
Papyrus > Diagrams > PapyrusUMLStateMachineDiagram
"Shown number of lines for opaque expressions/behaviors"
Indicate 1 or more.
This option enables to display OpaqueBehavior of internal transitions.
Yoann.
Re: CSS help to show opaque behavior of internal transitions [message #1783628 is a reply to message #1783579] Wed, 14 March 2018 17:06 Go to previous message
Hi Yoann,
The property bodyCutLength is equivalent to "Shown number of lines for opaque expressions/behaviors", as can be seen in https://wiki.eclipse.org/MDT/Papyrus/UserGuide/CSS#Style_properties
On this basis, I have recently added the following CSS rules and it works fine for all transitions!
bodyCutLength: 1;
Transition { /* for internal transitions */
bodyCutLength: 1;
Thank you for you attention.
Leandro.
Previous Topic:Papyrus 3.4 for the 21th May
Next Topic:Display Actor's name in Block Definition Diagram
Current Time: Sun Jan 17 00:51:42 GMT 2021
Powered by FUDForum. Page generated in 0.02050 seconds
