Home » Newcomers » Newcomers » Oxygen.2 exposes only partial system env variables!(Only partial system variables are being exposed internally to Eclipse)
Oxygen.2 exposes only partial system env variables! [message #1781017] Wed, 31 January 2018 15:25 Go to next message
Dennis Klotz is currently offline Dennis KlotzFriend
Is there a switch or configuration item that allows oxygen.2 to expose all of the system environment variables internally?
This used to work with Neon and Oxygen.1. I have a very simple JBOSS_HOME that isn't showing up in a terminal window of ecplise yet it is there. Without this and other env variables, camel will not work.
This is on windows 7 java 8 etc etc.
Any help is greatly appreciated.
Thank you.
Re: Oxygen.2 exposes only partial system env variables! [message #1781018 is a reply to message #1781017] Wed, 31 January 2018 15:42 Go to previous messageGo to next message
So as further information. A co-worker just replicated the setup on a windows 10 box and ALL of the env variables are present.
Apparently this is a windows 7 issue. :(
Re: Oxygen.2 exposes only partial system env variables! [message #1781042 is a reply to message #1781018] Wed, 31 January 2018 17:49 Go to previous message
I have created a defect here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=530574
Previous Topic:Errors of Spring
Next Topic:test
Current Time: Thu Aug 06 14:13:21 GMT 2020
Powered by FUDForum. Page generated in 0.01934 seconds
