Home » Eclipse Projects » EGit / JGit » Possible to do the same as "git checkout master -- ." command line?
Possible to do the same as "git checkout master -- ." command line? [message #1780472] Tue, 23 January 2018 01:30 Go to next message
Jerry Shea is currently offline Jerry SheaFriend
am hoping there is a way to do a checkout -- (overwrite local changes) from another branch. This is a very useful command line which can be used to revert your current branch to the same state as master.
The code I have tried looks like this:
// Starting on master, this checks out my branch
final CheckoutCommand checkoutCommand = git.checkout().
setCreateBranch(true).
setName(branch).
setUpstreamMode(CreateBranchCommand.SetupUpstreamMode.TRACK).
setStartPoint("remotes/origin/" + branch);
// this works fine
final Ref result = checkoutCommand.call();
Assert.notNull(result);
// I have tried this to "git checkout master -- ."
setName(branch). // "master" gives same result
setStartPoint("master"); // "remotes/origin/master" gives same result
// but result is null
I can't see a way to tell checkout to overwrite local changes ("--") or to get from master.
Any help gratefully received!!
Thanks, Jerry
Re: Possible to do the same as "git checkout master -- ." command line? [message #1780543 is a reply to message #1780472] Tue, 23 January 2018 19:49 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
try to add a call to setAllPaths(true) [1]
[1] http://download.eclipse.org/jgit/site/4.10.0.201712302008-r/apidocs/index.html
Re: Possible to do the same as "git checkout master -- ." command line? [message #1780830 is a reply to message #1780543] Mon, 29 January 2018 04:19 Go to previous messageGo to next message
Thanks, but I'm afraid when I change my code to
setCreateBranch(false).
setAllPaths(true).
Then I get
org.eclipse.jgit.api.errors.JGitInternalException: Cannot lock xxxxx/.git/index. Ensure that no other process has an open file handle on the lock file xxxxx/.git/index.lock, then you may delete the lock file and retry.
at org.eclipse.jgit.api.CheckoutCommand.call(CheckoutCommand.java:331)
at software.chronicle.release.fs.GitWrapperImpl.lambda$checkoutBranch$1(GitWrapperImpl.java:71)
at software.chronicle.release.fs.GitWrapperImpl.gitAction(GitWrapperImpl.java:144)
at software.chronicle.release.fs.GitWrapperImpl.checkoutBranch(GitWrapperImpl.java:59)
Re: Possible to do the same as "git checkout master -- ." command line? [message #1781500 is a reply to message #1780830] Wed, 07 February 2018 23:19 Go to previous message
maybe your application crashed earlier and left a stale file lock in the file system ?
Otherwise use OS tools to find out if there is another process having an open file handle on that file.
Previous Topic:how to extend egit to pre-define commit message
Next Topic:how update bare repository using jgit?
Current Time: Sun Apr 05 08:25:02 GMT 2020
Powered by FUDForum. Page generated in 0.05032 seconds
