Re: LSP: resolving types [message #1780338 is a reply to message #1780337] |
Sat, 20 January 2018 15:46 |
Where did you add it? The file is Generateds in ide so i put it to mydsl so there are finally two
don't know. I tested with vscode only sorry
Did you. Test your stuff with other clients?
You have to debug the client and or server to see what happens.
Maybe you need to create a better language server handling for for the Java language as there is currently there
( create an ide setup )
Twitter : @chrdietrich
[Updated on: Sat, 20 January 2018 15:52] Report message to a moderator
Re: LSP: resolving types [message #1780340 is a reply to message #1780338] |
Sat, 20 January 2018 16:58 |
i just saw you did not do the other stuff i did with customservermodule, XbaseProjectManage (at leasr create an empty urlclassloader there - you ususally would have to read and extract the deps from the gradle file - that is what the missing project support bug is about), XbaseJavaIoFileSystemScanner
Re: LSP: resolving types [message #1783237 is a reply to message #1783233] |
Fri, 09 March 2018 13:24 |
did you have a look at the offsets intellij sends? maybe there is somewhere a miscalculation (and or possibly a windows thingy)
thus it would be interesting what linenumber and offset is requested by idea and what the actual document has.
in your example i dont see anything that could be line 19 (zero based) character 2 (zero based)
=> you should have a look how the idea integration calculates these two
FUDForum. Page generated in 0.04122 seconds
