Home » Modeling » EMF » [XCORE] generated class files not updated
[XCORE] generated class files not updated [message #1780053] Tue, 16 January 2018 22:03 Go to next message
Theo Weiß is currently offline Theo WeißFriend
after upgrading to the latest eclipse version the code generation with xcore does not update existing class files when the model changes (new classes are created properly).
You can find my model here: https://github.com/theoweiss/openhab/blob/TF1217/bundles/binding/org.openhab.binding.tinkerforge/model/tinkerforge.xcore
What am I doing wrong?
Theo
Re: [XCORE] generated class files not updated [message #1780066 is a reply to message #1780053] Wed, 17 January 2018 04:16 Go to previous messageGo to next message
I'm completely tied up trying to get EMF's build migrated to Tycho right now so I don't have time to try to reproduce this. So you're saying that if you delete all the generated files, they do get regenerated? But after that the merging of any changes you make to the Xcore seems to fail? You might try updating to http://download.eclipse.org/modeling/emf/emf/updates/2.14milestones to see if there are fixes. Failing that, a small self-contained zipped project that reproduces the problem attached to a Bugzilla would be very helpful to let me investigate what's going wrong. I can't reproduce this problem with a small example with the current state in the master branch.
Ed Merks
Re: [XCORE] generated class files not updated [message #1780077 is a reply to message #1780066] Wed, 17 January 2018 08:10 Go to previous messageGo to next message
Yes.
Yes.
Ok, I will try the update.
May be it is failing because my model is quite big: ~ 1200 LOC and 44,4 kb?
Re: [XCORE] generated class files not updated [message #1780134 is a reply to message #1780077] Wed, 17 January 2018 20:39 Go to previous messageGo to next message
I've updated to 2.14milestones but it didn't fix the issue.
Re: [XCORE] generated class files not updated [message #1780148 is a reply to message #1780134] Thu, 18 January 2018 07:26 Go to previous message
That's unfortunate. :-( I'm also not able to reproduce a problem with a simple example. Please try to boil this down to a self-contained project that does reproduce the problem and attach that to a Bugzilla report.
Ed Merks
Previous Topic:[CDO] Security aspects for access rights
Next Topic:[XCore] / [EMF] Derived Attribute notifier definition/generation from model
Current Time: Tue Apr 16 14:15:05 GMT 2024
Powered by FUDForum. Page generated in 1.78483 seconds
