Home » Language IDEs » Objectteams » OTJ related JDT patch offered as update on clean 4.8.0 M4 w/o OTJ installed
OTJ related JDT patch offered as update on clean 4.8.0 M4 w/o OTJ installed [message #1779776] Fri, 12 January 2018 13:00 Go to next message
Lars Schütze is currently offline Lars SchützeFriend
Member
Just downloaded the new Eclipse 4.8.0 M4 for Java developers and after searching for updates it offered me A patch for JDT from Object Teams. I changed nothing and just started the bare Eclipse IDE (ie., there is no OTJ installed right now).
I think I can recall that there once was a "bug" where something OTJ has been offered as update that should not be. Is this also the case now?
The downloaded patch: Object Teams Patch for JDT/Core 2.7.0.201712091238
Re: OTJ related JDT patch offered as update on clean 4.8.0 M4 w/o OTJ installed [message #1779858 is a reply to message #1779776] Sun, 14 January 2018 21:55 Go to previous messageGo to next message
Stephan Herrmann is currently offline Stephan HerrmannFriend
You're right this had been https://bugs.eclipse.org/350133 which was resolved as of Luna M7.
Looking at current meta data and comparing against previous versions, the fix for said bug seems to be broken.
=> https://bugs.eclipse.org/529800
Thanks for the notice, Lars!
Re: OTJ related JDT patch offered as update on clean 4.8.0 M4 w/o OTJ installed [message #1797048 is a reply to message #1779776] Wed, 24 October 2018 12:13 Go to previous messageGo to next message
Mirro polyno is currently offline Mirro polynoFriend
Lars Schütze wrote on Fri, 12 January 2018 13:00
Taking a gander at current meta information and looking at against past adaptations, the fix for said bug is by all accounts broken.
Re: OTJ related JDT patch offered as update on clean 4.8.0 M4 w/o OTJ installed [message #1797291 is a reply to message #1797048] Mon, 29 October 2018 15:22 Go to previous message
can you be more specific?
Previous Topic:LIBPATH issue with GTK+ on AIX
Next Topic:Prepare ObjectTeams for Java 9 and beyond
Current Time: Sat Apr 17 14:44:34 GMT 2021
Powered by FUDForum. Page generated in 0.03020 seconds
