Home » Eclipse Projects » Kura » Permanent deployment of plugins to kura(Unable to permanently deploy jars to kura)
Permanent deployment of plugins to kura [message #1779740] Fri, 12 January 2018 00:28 Go to next message
Divya Nar is currently offline Divya NarFriend
I am trying to deploy few jars permanently to kura.
So i have put the jars under /opt/eclipse/kura/plugins folder.
I also updated the config.ini under /opt/eclipse/kura/kura/
by updating osgi.bundles to have reference to the plugins i have put.
These plugins are for camel-netty.
When i restarted kura and try to deploy my application bundle to kura, My camel route starts and stops immediately.
But if i install the bundles to kura everytime when kura is started, It works fine without any issues.
PFA config.ini file and the log message.
[Updated on: Fri, 12 January 2018 00:32]
Report message to a moderator
Re: Permanent deployment of plugins to kura [message #1779896 is a reply to message #1779740] Mon, 15 January 2018 14:10 Go to previous messageGo to next message
Matteo Maiero is currently offline Matteo MaieroFriend
did you try to access the OSGi Console with telnet 127.0.0.1 5002?
In which state do the bundles are?
Matteo
Re: Permanent deployment of plugins to kura [message #1779916 is a reply to message #1779896] Mon, 15 January 2018 18:47 Go to previous messageGo to next message
Hi Matteo,
yes i did access them.
All the bundles are shown as - active state.
Divya
Re: Permanent deployment of plugins to kura [message #1780968 is a reply to message #1779916] Tue, 30 January 2018 15:34 Go to previous message
Marco Noto is currently offline Marco NotoFriend
I think You should add your plugin in the dpa.properties file.
Previous Topic:Need Help: Error when deploy Greenhouse sample on RPi3b
Next Topic:how to remove configuration data when uninstall bundle
Current Time: Sun Jan 17 10:57:16 GMT 2021
Powered by FUDForum. Page generated in 0.02243 seconds
