Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT Exception No more callbacks - Display
SWT Exception No more callbacks - Display [message #1779701] Thu, 11 January 2018 12:20
Umut Kazan is currently offline Umut KazanFriend
i have a class extends from Thread and here is the run method;
display = PlatformUI.createDisplay();
Shell shell = new Shell(display, SWT.CENTER | SWT.TITLE | SWT.PRIMARY_MODAL | SWT.ON_TOP);
while (!shell.isDisposed())
	if (!display.readAndDispatch())
		String mes = logger.getMessage();
		if (mes != null)
			// shell.setText(mes);
			processMessage = mes;
		display.sleep();
display.dispose();
because of the PlatformUI.createDisplay() every time this is called, new Display created and registered to Display class' "Displays" list. After a while SWT exception occurs. How can i dispose this Display? Code doesn't reach the display.dispose()
[Updated on: Mon, 15 January 2018 06:13]
Report message to a moderator
Previous Topic:How to call OLE interface with LPWSTR
Next Topic:Update image when image-file changes
Current Time: Sat May 30 00:24:23 GMT 2020
Powered by FUDForum. Page generated in 0.01907 seconds
