A way to reduce memory cost during create diagram [message #1779440] |
Mon, 08 January 2018 03:49 |
mind calm Messages: 57 Registered: July 2017 |
Member |
As mentioned in another topic, https://www.eclipse.org/forums/index.php/m/1775006/ , i was found memory grows in speed of O(n²) by model size. Now i have a way to fix it.
In function DiagramDialectServices.createRepresentation(),
before canonicalSynchronizer.synchronize(), we can remove the TransactionChangeRecorder from gmfDiag.eAdapters(). After canonicalSynchronizer.synchronize(), we add the TransactionChangeRecorder back.
The TransactionChangeRecorder is used for undo/redo, during create representation, each creation of a nodeImpl will trigger TransactionChangeRecorder to create a FeatureChangImpl for recording the value before create this nodeImpl, so the memory grows in O(n²).
As my test, the memory sharply reduced while the model size is huge. But i don't know whether the modification brings other potential issues.
In my opinion, the representation creation can not be undo is acceptable.
Best regards!
by Keep Mind Calm
FUDForum. Page generated in 0.02648 seconds
