Re: Consistent Datatype for values [message #1779365 is a reply to message #1779364] |
Fri, 05 January 2018 17:48 |
Dennis Melzer Messages: 48 Registered: December 2014 |
Member |
Christian Dietrich wrote on Fri, 05 January 2018 17:45you have already a MyDslValidator pregenerated. yes
Okay thanks :)
Antoher related question. A attribute (like in Java) should always start with a character. My solution is:
terminal FIELD_VALUE:
('A'..'Z' | 'a'..'z') ('A'..'Z' | 'a'..'z' | '0'..'9' | '.' | '_' | '-')*;
Is this ok? Or should i create a validation as well?
[Updated on: Fri, 05 January 2018 17:51] Report message to a moderator
Re: Consistent Datatype for values [message #1779368 is a reply to message #1779366] |
Fri, 05 January 2018 17:52 |
Member |
Christian Dietrich wrote on Fri, 05 January 2018 17:50that's ok, depends on other places you use similar IDs.
Okay, then i will try to create a validation
EDIT: okay now i have the same issue like in my other thread all values are strings ;). So i cannot check the data type. First i have to fix this, before i can create a validation
[Updated on: Fri, 05 January 2018 18:08] Report message to a moderator
FUDForum. Page generated in 0.03497 seconds
