Home » Eclipse Projects » EclipseLink » Join condition of INNER JOIN
Join condition of INNER JOIN [message #1779329] Fri, 05 January 2018 13:26 Go to next message
Frederick Gaens is currently offline Frederick GaensFriend
I recently got a question from our DBA who wanted me to rewrite a query with an INNER JOIN so that the join condition would be in the FROM clause.
Because the JPQL query was already OK, I started looking through the Eclipselink documentation and came across this:
For INNER joins EclipseLink will normally append the join condition to the WHERE clause, but this can be configured in the DatabasePlatform.
Is there any way to force Eclipselink to generate a query where the join condition of an inner join will be in the from clause?
Re: Join condition of INNER JOIN [message #1779496 is a reply to message #1779329] Mon, 08 January 2018 17:32 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris DelahuntFriend
https://bugs.eclipse.org/bugs/show_bug.cgi?id=246356 shows how to enable the join to be put in the from clause in EclipseLink 2.4; this same method should be able to turn off this behaviour so that joins are done in the where clause for all queries by default. You will need to call platform.setPrintInnerJoinInWhereClause(true); within a session customizer event as described here https://wiki.eclipse.org/EclipseLink/UserGuide/JPA/Advanced_JPA_Development/Customizers where you use the session to get the databasePlatform set through your configuration, or change it to a custom implementation.
Best Regards,
Chris
Re: Join condition of INNER JOIN [message #1781420 is a reply to message #1779496] Wed, 07 February 2018 08:06 Go to previous messageGo to next message
So I created a session customizer
package be.dkv.evvplus.configuration.eclipselink;
import org.eclipse.persistence.config.SessionCustomizer;
import org.eclipse.persistence.sessions.Session;
public class EclipseLinkSessionCustomizer implements SessionCustomizer {
    public void customize(Session session) throws Exception {
        session.getPlatform().setPrintInnerJoinInWhereClause(false);
and I added it to the persistence.xml
<property name="eclipselink.session.customizer" value="be.dkv.evvplus.configuration.eclipselink.EclipseLinkSessionCustomizer" />
When I try to deploy it on GlassFish, I'm getting the following error:
java.lang.NoSuchMethodError: org.eclipse.persistence.platform.database.DatabasePlatform.setPrintInnerJoinInWhereClause(Z)V
	at be.dkv.evvplus.configuration.eclipselink.EclipseLinkSessionCustomizer.customize(EclipseLinkSessionCustomizer.java:9)
	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.processSessionCustomizer(EntityManagerSetupImpl.java:1985)
	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.updateSession(EntityManagerSetupImpl.java:1953)
	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:471)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:188)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:277)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:294)
	at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:272)
	at org.glassfish.persistence.jpa.PersistenceUnitLoader.loadPU(PersistenceUnitLoader.java:211)
	at org.glassfish.persistence.jpa.PersistenceUnitLoader.<init>(PersistenceUnitLoader.java:120)
	at org.glassfish.persistence.jpa.JPADeployer$1.visitPUD(JPADeployer.java:224)
	at org.glassfish.persistence.jpa.JPADeployer$PersistenceUnitDescriptorIterator.iteratePUDs(JPADeployer.java:495)
	at org.glassfish.persistence.jpa.JPADeployer.createEMFs(JPADeployer.java:233)
	at org.glassfish.persistence.jpa.JPADeployer.prepare(JPADeployer.java:168)
	at com.sun.enterprise.v3.server.ApplicationLifecycle.prepareModule(ApplicationLifecycle.java:871)
	at org.glassfish.javaee.full.deployment.EarDeployer.prepareBundle(EarDeployer.java:290)
	at org.glassfish.javaee.full.deployment.EarDeployer.access$200(EarDeployer.java:86)
	at org.glassfish.javaee.full.deployment.EarDeployer$1.doBundle(EarDeployer.java:141)
	at org.glassfish.javaee.full.deployment.EarDeployer$1.doBundle(EarDeployer.java:138)
	at org.glassfish.javaee.full.deployment.EarDeployer.doOnBundles(EarDeployer.java:215)
	at org.glassfish.javaee.full.deployment.EarDeployer.doOnAllTypedBundles(EarDeployer.java:224)
	at org.glassfish.javaee.full.deployment.EarDeployer.doOnAllBundles(EarDeployer.java:250)
	at org.glassfish.javaee.full.deployment.EarDeployer.prepare(EarDeployer.java:138)
	at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:410)
	at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:240)
	at org.glassfish.deployment.admin.DeployCommand.execute(DeployCommand.java:389)
	at com.sun.enterprise.v3.admin.CommandRunnerImpl$1.execute(CommandRunnerImpl.java:348)
	at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:363)
	at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:1066)
	at com.sun.enterprise.v3.admin.CommandRunnerImpl.access$1200(CommandRunnerImpl.java:95)
	at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1291)
	at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1259)
	at org.glassfish.admin.rest.ResourceUtil.runCommand(ResourceUtil.java:214)
	at org.glassfish.admin.rest.ResourceUtil.runCommand(ResourceUtil.java:207)
	at org.glassfish.admin.rest.resources.TemplateListOfResource.createResource(TemplateListOfResource.java:148)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at com.sun.jersey.spi.container.JavaMethodInvokerFactory$1.invoke(JavaMethodInvokerFactory.java:60)
	at com.sun.jersey.server.impl.model.method.dispatch.AbstractResourceMethodDispatchProvider$ResponseOutInvoker._dispatch(AbstractResourceMethodDispatchProvider.java:205)
	at com.sun.jersey.server.impl.model.method.dispatch.ResourceJavaMethodDispatcher.dispatch(ResourceJavaMethodDispatcher.java:75)
	at com.sun.jersey.server.impl.uri.rules.HttpMethodRule.accept(HttpMethodRule.java:288)
	at com.sun.jersey.server.impl.uri.rules.SubLocatorRule.accept(SubLocatorRule.java:134)
	at com.sun.jersey.server.impl.uri.rules.RightHandPathRule.accept(RightHandPathRule.java:147)
	at com.sun.jersey.server.impl.uri.rules.ResourceClassRule.accept(ResourceClassRule.java:108)
	at com.sun.jersey.server.impl.uri.rules.RootResourceClassesRule.accept(RootResourceClassesRule.java:84)
	at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1469)
	at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1400)
	at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1349)
	at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1339)
	at com.sun.jersey.server.impl.container.grizzly.GrizzlyContainer._service(GrizzlyContainer.java:182)
	at com.sun.jersey.server.impl.container.grizzly.GrizzlyContainer.service(GrizzlyContainer.java:147)
	at org.glassfish.admin.rest.adapter.RestAdapter.service(RestAdapter.java:148)
	at com.sun.grizzly.tcp.http11.GrizzlyAdapter.service(GrizzlyAdapter.java:179)
	at com.sun.enterprise.v3.server.HK2Dispatcher.dispath(HK2Dispatcher.java:117)
	at com.sun.enterprise.v3.services.impl.ContainerMapper$Hk2DispatcherCallable.call(ContainerMapper.java:354)
	at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:195)
	at com.sun.grizzly.http.ProcessorTask.invokeAdapter(ProcessorTask.java:860)
	at com.sun.grizzly.http.ProcessorTask.doProcess(ProcessorTask.java:757)
	at com.sun.grizzly.http.ProcessorTask.process(ProcessorTask.java:1056)
	at com.sun.grizzly.http.DefaultProtocolFilter.execute(DefaultProtocolFilter.java:229)
	at com.sun.grizzly.DefaultProtocolChain.executeProtocolFilter(DefaultProtocolChain.java:137)
	at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:104)
	at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:90)
	at com.sun.grizzly.http.HttpProtocolChain.execute(HttpProtocolChain.java:79)
	at com.sun.grizzly.ProtocolChainContextTask.doCall(ProtocolChainContextTask.java:54)
	at com.sun.grizzly.SelectionKeyContextTask.call(SelectionKeyContextTask.java:59)
	at com.sun.grizzly.ContextTask.run(ContextTask.java:71)
	at com.sun.grizzly.util.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:532)
	at com.sun.grizzly.util.AbstractThreadPool$Worker.run(AbstractThreadPool.java:513)
	at java.lang.Thread.run(Thread.java:745)
Re: Join condition of INNER JOIN [message #1781724 is a reply to message #1781420] Mon, 12 February 2018 15:02 Go to previous message
I'd guess this is due to an issue with the version you compiled against not being the same as the version you are running against.
Previous Topic:Optimizing EclipseLink generated SQL
Next Topic:Mapping between the property name of a DynamicType and the Java Class name
Current Time: Sun Apr 05 23:35:26 GMT 2020
Powered by FUDForum. Page generated in 0.01682 seconds
