Home » Modeling » OCL » OCLinEcore editor broken after update
OCLinEcore editor broken after update [message #1779096] Tue, 02 January 2018 18:08 Go to next message
Sina Madani is currently offline Sina MadaniFriend
I updated to the most recent version of OCL (6.4.0v20171215-1833) on Eclipse Oxygen (October 2017). After doing this on two computers I found that this seems to break the OCLinEcore editor (but not the CompleteOCL editor), with the following stack trace when opening an Ecore file. It should be noted that I have Xtext installed too. I wonder what could be causing this, as upgrading Eclipse OCL did not previously cause this issue.
org.eclipse.core.runtime.CoreException: org/eclipse/xtext/ide/editor/contentassist/antlr/internal/BaseInternalContentAssistParser (occurred in org.eclipse.ocl.xtext.oclinecore.ui.OCLinEcoreExecutableExtensionFactory)
	at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.handleCreationError(AbstractGuiceAwareExecutableExtensionFactory.java:96)
	at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:64)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.ui.internal.WorkbenchPlugin.lambda$0(WorkbenchPlugin.java:288)
	at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:285)
	at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:232)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:329)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:293)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPart(CompatibilityEditor.java:63)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:331)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:990)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:955)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:124)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:399)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:318)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:992)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:661)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:767)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:738)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:732)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:716)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1293)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:97)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:679)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:69)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:675)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:546)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:530)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:70)
	at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:137)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:79)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:61)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:704)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1076)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/xtext/ide/editor/contentassist/antlr/internal/BaseInternalContentAssistParser
	at java.lang.Class.getDeclaredMethods0(Native Method)
	at java.lang.Class.privateGetDeclaredMethods(Class.java:2701)
	at java.lang.Class.getDeclaredMethods(Class.java:1975)
	at com.google.inject.spi.InjectionPoint.getInjectionPoints(InjectionPoint.java:662)
	at com.google.inject.spi.InjectionPoint.forInstanceMethodsAndFields(InjectionPoint.java:356)
	at com.google.inject.internal.ConstructorBindingImpl.getInternalDependencies(ConstructorBindingImpl.java:151)
	at com.google.inject.internal.InjectorImpl.getInternalDependencies(InjectorImpl.java:585)
	at com.google.inject.internal.InjectorImpl.cleanup(InjectorImpl.java:543)
	at com.google.inject.internal.InjectorImpl.initializeJitBinding(InjectorImpl.java:529)
	at com.google.inject.internal.InjectorImpl.createJustInTimeBinding(InjectorImpl.java:847)
	at com.google.inject.internal.InjectorImpl.createJustInTimeBindingRecursive(InjectorImpl.java:772)
	at com.google.inject.internal.InjectorImpl.getJustInTimeBinding(InjectorImpl.java:256)
	at com.google.inject.internal.InjectorImpl.getBindingOrThrow(InjectorImpl.java:205)
	at com.google.inject.internal.InjectorImpl.getInternalFactory(InjectorImpl.java:853)
	at com.google.inject.internal.FactoryProxy.notify(FactoryProxy.java:46)
	at com.google.inject.internal.ProcessedBindingData.runCreationListeners(ProcessedBindingData.java:50)
	at com.google.inject.internal.InternalInjectorCreator.initializeStatically(InternalInjectorCreator.java:133)
	at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:106)
	at com.google.inject.Guice.createInjector(Guice.java:95)
	at com.google.inject.Guice.createInjector(Guice.java:72)
	at com.google.inject.Guice.createInjector(Guice.java:62)
	at org.eclipse.ocl.xtext.oclinecore.ui.internal.OCLinEcoreActivator.createInjector(OCLinEcoreActivator.java:74)
	at org.eclipse.ocl.xtext.oclinecore.ui.internal.OCLinEcoreActivator.getInjector(OCLinEcoreActivator.java:62)
	at org.eclipse.ocl.xtext.oclinecore.ui.OCLinEcoreExecutableExtensionFactory.getInjector(OCLinEcoreExecutableExtensionFactory.java:33)
	at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:53)
	... 131 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.xtext.ide.editor.contentassist.antlr.internal.BaseInternalContentAssistParser cannot be found by org.eclipse.ocl.xtext.oclinecore.ui_1.4.0.v20171211-1247
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:484)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
	... 156 more
Re: OCLinEcore editor broken after update [message #1779098 is a reply to message #1779096] Tue, 02 January 2018 18:38 Go to previous messageGo to next message
is a sure sign that OCLinEcore and Xtext are incompatible. What version of Xtext are you using?
20171215-1833 is an OCL N-build so it was built and tested against the latest Xtext nightly which has just started on Xtext 2.14.
I'll be producing a I-build shortly to accommodate the new OCL builder that now gives auto-validation of embedded OCL in Ecore. I'll keep an eye out for funnies.
Ed Willink
Ed Willink
Re: OCLinEcore editor broken after update [message #1779116 is a reply to message #1779098] Tue, 02 January 2018 23:57 Go to previous messageGo to next message
Hi Ed,
I updated Xtext to the nightly build and it worked! Though I wonder why Xtext wasn't also updated alongside OCL.
Sina
Re: OCLinEcore editor broken after update [message #1779139 is a reply to message #1779116] Wed, 03 January 2018 06:33 Go to previous messageGo to next message
It appears that org/eclipse/xtext/ide/editor/contentassist/antlr/internal/BaseInternalContentAssistParser is a new base class refactored out 29 days ago. But that shouldn't matter since OCL shouldn't be referencing it, which it doesn't. OCL uses the old org.eclipse.xtext.ui rather than the different org.eclipse.xtext.ide files. I suspect that Xtext has messed up in conjunction with the Guice injection process. Once I've investigated. I'll maybe raise an Xtext bug. Thanks for the heads up; this is why we do N-builds.
Ed Willink
Re: OCLinEcore editor broken after update [message #1779152 is a reply to message #1779139] Wed, 03 January 2018 09:26 Go to previous messageGo to next message
Xtext bug raised: https://bugs.eclipse.org/bugs/show_bug.cgi?id=529361
OCL workaround bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=529363
Ed Willink
Re: OCLinEcore editor broken after update [message #1779333 is a reply to message #1779152] Fri, 05 January 2018 14:06 Go to previous message
The Xtext problem has been fixed. The latest OCL build can now run with Xtext 2.13 again.
Ed Willink
Previous Topic:Strange behavior on MS/Win with OCL
Next Topic:EMF reflection in completeOCL (Pivot)
Current Time: Tue Feb 18 09:23:00 GMT 2020
Powered by FUDForum. Page generated in 0.12079 seconds
