MacOS and Launching a new Eclipse Application [message #1779090] |
Tue, 02 January 2018 14:10  |
Mehmet Karaman Messages: 63 Registered: November 2012 Location: Berlin |
Member |
recently I've switched from a Windows PC to Mac, Installed eclipse and set up my workspace as usual. After launching a new Eclipse application in debug/run mode, my eclipse window shows up, but doesn't react on anything. Wether I can click on close, minimize and maximize, nor I can use its menu or any view and toolbar action. The console output is quoted below:
2018-01-02 14:37:34.648 java[2401:118730] *** WARNING: Method userSpaceScaleFactor in class NSWindow is deprecated on 10.7 and later. It should not be used in new applications. Use convertRectToBacking: instead.
2018-01-02 14:37:34.721 java[2401:118730] *** WARNING: Method userSpaceScaleFactor in class NSView is deprecated on 10.7 and later. It should not be used in new applications. Use convertRectToBacking: instead.
!SESSION 2018-01-02 14:37:28.734 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_152
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=de_DE
Framework arguments: -application org.eclipse.ui.ide.workbench
Command-line arguments: -application org.eclipse.ui.ide.workbench -data /Users/mkaraman/eclipse/promodsl-dev-futurelab/ws/../runtime-New_configuration -dev file:/Users/mkaraman/eclipse/promodsl-dev-futurelab/ws/.metadata/.plugins/org.eclipse.pde.core/New_configuration/dev.properties -os macosx -ws cocoa -arch x86_64 -consoleLog
!ENTRY org.eclipse.core.net 1 0 2018-01-02 14:37:35.002
!MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences
!ENTRY org.eclipse.ui 4 4 2018-01-02 14:39:30.957
!MESSAGE Unable to create menu item "null", command "org.eclipse.ui.cocoa.minimizeWindow" not defined
!ENTRY org.eclipse.ui 4 4 2018-01-02 14:39:30.958
!MESSAGE Unable to create menu item "null", command "org.eclipse.ui.cocoa.zoomWindow" not defined
!MESSAGE Unable to create menu item "null", command "org.eclipse.ui.cocoa.fullscreenWindow" not defined
!ENTRY org.eclipse.ui 4 4 2018-01-02 14:39:30.959
!MESSAGE Unable to create menu item "null", command "org.eclipse.ui.cocoa.arrangeWindowsInFront" not defined
What could be the problem? Thanks in advance.
Best regards
M.Karaman
[Updated on: Tue, 02 January 2018 14:19] Report message to a moderator
FUDForum. Page generated in 0.02037 seconds
