Home » Language IDEs » Eclipse Web Tools Platform Project (WTP) » [JSON Editor]Completion for JSon schema working only on first-level?
[JSON Editor]Completion for JSon schema working only on first-level? [message #1779035] Fri, 29 December 2017 13:56
Aurélien Pupier is currently offline Aurélien PupierFriend
I have a custom json-schema and associated it with my file.
Schema is here https://github.com/syndesisio/syndesis/blob/master/app/rest/model/src/main/resources/syndesis/syndesis-extension-definition-schema.json
Sample file:
"version":"",
"name":"",
"extensionId":"",
"icon":"",
"description":"",
  "actions": [
      "actionType": "extension",
      "id": "log-body",
      "name": "simple-log-body",
      "description": "A simple xml based logging extension",
      "tags": [
        "xml"
      "descriptor": {
        "kind": "ENDPOINT",
        "entrypoint": "direct:log-body",
        "inputDataShape": {
          "kind": "any"
        "outputDataShape": {
          "kind": "any"
        "propertyDefinitionSteps": []
  "tags": [
    "feature",
    "experimental"
The completion is working for the attributes of first level (version, name, extensionId, icon, description, actions, tags) but I have no completion for attributes inside actions for instance.
Is it supported?
Is it because the schema is not written correctly?
Is it because the json schema metamodel is not a supported one (http://json-schema.org/draft-04/schema#) ?
What is the good place to put breakpoints to investigate on that if it should work and there is a bug somewhere?
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Previous Topic:HTTP Preview server not exists (Eclipse Neon and WTP 3.9.1 installed)
Next Topic:Why I cannot run Eclipse?
Current Time: Sat Oct 31 03:13:22 GMT 2020
Powered by FUDForum. Page generated in 0.02214 seconds
