Home » Eclipse Projects » Oomph » File does not contain a valid product
File does not contain a valid product [message #1779029] Fri, 29 December 2017 09:52 Go to next message
Tony Hedoux is currently offline Tony HedouxFriend
Hello everyone :)
I am trying to load a product setup file with the OOMPH installer, and the error I obtain is : "File .... does not contain a valid product", without any details.
I have try to load this file with OOMPH setup editor directly, and the editor does not provide any errors or warning about its format.
I can not share the product file, because there is a lot of internal repository identified in it.
My question is : how I can obtain more details about Why it is a seen as an invalid product by the OOMPH installer?
Thx for your help!
Tony
  • Attachment: Error.png
    (Size: 10.58KB, Downloaded 214 times)
ALL4TEC
Re: File does not contain a valid product [message #1779030 is a reply to message #1779029] Fri, 29 December 2017 10:35 Go to previous messageGo to next message
The code that's doing the processing of the URIs looks like this:
    protected boolean processResources()
      List<Product> validProducts = new ArrayList<Product>();
      List<Product> invalidProducts = new ArrayList<Product>();
      List<URI> invalidURIs = new ArrayList<URI>();
      ResourceSet resourceSet = editingDomain.getResourceSet();
      for (URI uri : getURIs())
        BaseResource resource = BaseUtil.loadResourceSafely(resourceSet, uri);
        Product product = (Product)EcoreUtil.getObjectByType(resource.getContents(), SetupPackage.Literals.PRODUCT);
        if (product == null)
          invalidURIs.add(uri);
        else if (product.eContainer() != null)
          invalidProducts.add(product);
        else
Given the message you show, it's hitting "product == null" case so the file does not contain a Product. Perhaps it contains a Project? Or something else? What is the first element you see in the XML representation? It should look similar to this:
<setup:Product
    xmi:version="2.0"
    xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
    xmlns:setup.p2="http://www.eclipse.org/oomph/setup/p2/1.0"
    name="my.product"
    label="My Product">
Ed Merks
Re: File does not contain a valid product [message #1779031 is a reply to message #1779030] Fri, 29 December 2017 11:33 Go to previous message
You are right, the XML file is starting with a Project.
I will dig a bit to find why it is the case and which difference it implies to use it.
Thanks for the quick and accurate (as always... :p ) answer Ed :)
Tony
ALL4TEC
Previous Topic:Running an arbitraty project.setup
Next Topic:Hybrid .target + targlet project
Current Time: Sun Jan 19 00:18:39 GMT 2025
Powered by FUDForum. Page generated in 0.02474 seconds
