Home » Eclipse Projects » Papyrus for Real Time » creating composite state
creating composite state [message #1778929] Sun, 24 December 2017 20:11 Go to next message
reza ahmadi is currently offline reza ahmadiFriend
Member
What is the easiest way to put a set of states and transitions into a composite state? Simply copying/pasting does not work (i am using papyrus-rt 1.0 on a macOs). States are pasted into the composite state, but not the transitions.
Would not it be useful if one could do this using a menu option/command?
Thanks.
Re: creating composite state [message #1779112 is a reply to message #1778929] Tue, 02 January 2018 22:01 Go to previous messageGo to next message
Charles Rivet is currently offline Charles RivetFriend
This is indeed an interesting feature and I could not readily think of an easy way to do this. Maby someone else on this list can think of a way.
In the mean time, I would recommen you create a bug for such an improvement so tha tit can be properly tracked. You can do so by following this link: https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Papyrus-rt
/Charles Rivet
Re: creating composite state [message #1779713 is a reply to message #1778929] Thu, 11 January 2018 15:00 Go to previous messageGo to next message
Ernesto Posse is currently offline Ernesto PosseFriend
Are you copying and pasting in the model editor or in the model explorer?
Re: creating composite state [message #1779729 is a reply to message #1779713] Thu, 11 January 2018 21:26 Go to previous messageGo to next message
Member
I have tried both.
Re: creating composite state [message #1779730 is a reply to message #1779713] Thu, 11 January 2018 21:26 Go to previous message
Member
I have tried both.
Previous Topic:How to override targetStartup
Next Topic:exporting a hierarchical state machine to images
Current Time: Mon Jun 24 15:13:47 GMT 2019
Powered by FUDForum. Page generated in 0.02855 seconds
