Home » Modeling » Graphiti » Can I draw a line rather than a connection?
Can I draw a line rather than a connection? [message #1778907] Sat, 23 December 2017 14:31 Go to next message
xi yahui is currently offline xi yahuiFriend
Member
I want to draw a horizontal line. It doesn't need to be connected to other shape. It can be selected like the connection rather than the rectangle.
How can i do?
Re: Can I draw a line rather than a connection? [message #1778981 is a reply to message #1778907] Wed, 27 December 2017 14:08 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
I would suggest to use a shape and a line as its graphics algorithm. Probably you will need to disable moving the shape or resizing via the feature provider.
HTH,
Michael
Re: Can I draw a line rather than a connection? [message #1778994 is a reply to message #1778981] Thu, 28 December 2017 00:45 Go to previous messageGo to next message
Member
I can use a shape. But I must to draw a float rectangle for adding a shape. Can i add a shape like the connection behavior?
Re: Can I draw a line rather than a connection? [message #1779002 is a reply to message #1778994] Thu, 28 December 2017 07:32 Go to previous messageGo to next message
Not sure if I got your point, but you should be able to use a Rectangle (or a line) that has a vertical dimension of 0 (in case of a horizontal line).
Michael
Re: Can I draw a line rather than a connection? [message #1779012 is a reply to message #1779002] Thu, 28 December 2017 11:57 Go to previous messageGo to next message
Member
Yes, i can use a rectangle shape. The behavior of adding a shape is to draw a rectangle. I wish to add the shape like add the connection. That is to say, I wish to set the source point and target point through mouse click.
Re: Can I draw a line rather than a connection? [message #1779015 is a reply to message #1779012] Thu, 28 December 2017 14:02 Go to previous messageGo to next message
Sorry, I don't think that this is possible.
Michael
Re: Can I draw a line rather than a connection? [message #1779023 is a reply to message #1779015] Fri, 29 December 2017 00:46 Go to previous message
Member
Thanks.
Previous Topic:How to directedit text in customfeature?
Next Topic:How to set the order of shape?
Current Time: Tue Nov 24 01:57:44 GMT 2020
Powered by FUDForum. Page generated in 0.02076 seconds
