Eclipse Oxygen stops on startup at "Loading org.eclipse.oomph.setup.ui" step [message #1778899] |
Sat, 23 December 2017 08:28 |
Pierre Granouillet Messages: 3 Registered: December 2017 |
Hi everybody,
First of all, I would say that I'm completely new either on Eclipse and on the forum, so pardon me if I misuse it.
I have installed Eclispe Oxygen with PyDev extension for Python. Everything seemed to work fine during a couple of weeks. But after a while without using it, Eclipse startup blocks on the "Loading org.eclipse.oomph.setup.ui" step (as can be seen on the loading screen).
I really have no clue about what happens due to my weak technical skills. So if one of you could help me, I would really appreciate.
Here is the log trace I obtain in "C:\Users\<UserName>\eclipse-workspace\.metadata" directory. Strangely, I don't have anything for today:
!SESSION 2017-12-17 08:52:33.295 -----------------------------------------------
eclipse.buildId=4.7.1.M20170906-1700
java.version=1.8.0_151
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=fr_FR
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.equinox.p2.reconciler.dropins 4 0 2017-12-17 08:52:34.911
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start() of bundle org.eclipse.equinox.p2.reconciler.dropins.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:800)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1628)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1608)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1579)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1522)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: java.lang.IllegalStateException: Registry Directory not available: c:\Program Files\eclipse\p2\org.eclipse.equinox.p2.engine\profileRegistry.
at org.eclipse.oomph.p2.internal.core.LazyProfileRegistry.getProfileMap(LazyProfileRegistry.java:236)
at org.eclipse.oomph.p2.internal.core.LazyProfileRegistry.getProfileMap(LazyProfileRegistry.java:227)
at org.eclipse.oomph.p2.internal.core.LazyProfileRegistry.containsProfile(LazyProfileRegistry.java:208)
at org.eclipse.equinox.internal.p2.engine.ProfilePreferences.containsProfile(ProfilePreferences.java:112)
at org.eclipse.equinox.internal.p2.engine.ProfilePreferences.load(ProfilePreferences.java:259)
at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:370)
at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:623)
at org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:766)
at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:629)
at org.eclipse.core.internal.preferences.RootPreferences.getNode(RootPreferences.java:105)
at org.eclipse.core.internal.preferences.RootPreferences.node(RootPreferences.java:84)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.getSharedPreferences(AbstractRepositoryManager.java:518)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.restoreRepositories(AbstractRepositoryManager.java:1016)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.basicGetRepository(AbstractRepositoryManager.java:181)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:649)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.initializeMetadataRepository(RepositoryListener.java:104)
at org.eclipse.equinox.internal.provisional.p2.directorywatcher.RepositoryListener.<init>(RepositoryListener.java:59)
at org.eclipse.equinox.internal.p2.reconciler.dropins.DropinsRepositoryListener.<init>(DropinsRepositoryListener.java:82)
at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.watchDropins(Activator.java:540)
at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start(Activator.java:173)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772)
... 12 more
Root exception:
Attachment: .log
(Size: 177.78KB, Downloaded 165 times)
FUDForum. Page generated in 0.08317 seconds
